Quote Originally Posted by isakl View Post
The very first tests that I did was seeing at what lowest RPM I can run it.
To my amazement, it was no problem at all running even it as low as 200RPM.
At first it had very little torque at this speed. After playing with some parameters of the inverter, I managed to throw the full 10Amps while turning 200RPM.
Hi, would it be possible to post what parameters you have changed to the VFD.
Thanks, Jeff
