Originally Posted by
Tbkahuna
Took the top cover off the sump. Hmmmm, lots of skin. Most of it was to the right side of the baffle, while the pump is on the left. I pulled that mostly out and made sure the bottom of the pump inlet was clear. Wiped everything else off and it is now working.
I am knew to the regular use of coolant so I would still like any feedback from anyone on what I need to do to maintain the coolant system.
What is the "skin" I found in there? Will I need to remove that every few months? I use the machine several evenings a week, and as much as I can on weekends.
Anything else to prevent the skin?
I am using Tormach's synthetic coolant mixed to spec. I check it every week with a refractometer.
Thanks for the help.
