587,326 active members*
2,755 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How many hours do you have on your fadals
Results 1 to 18 of 18
    Feb 2006
    127
    Wink How many hours do you have on your fadals
    Hi Guys..
    Just curious.. I recently purchased a used 4020 and had my tech do a once over on the machine to make sure eveything is in check.. Got an A+ from the tech and asked how many hours were on the machine.. Well its a 1999 4020 A and its shows 2200 hours of cutting time..
    In my opinion, its pretty low hours..
    What is your year and how many hours do you have on it ??
    Would appreciate your comments..
    Thanks Chips !!
    Jul 2009
    317
    My VMC 40 is 27 years old (?)/; upgraded in 2000; has 6k hours.
    900
    Remember that the clocks can be MANUALLY ZEROED any any time so the total hours may or may not be accurate!
    Neal
    Jun 2004
    236
    Dumb question, but how to you check for this?, I cannot find procedure in manual for checking time usage, Im now interested
    Visit our face book page, search on FaceBook; High-Desert-Precision-CNC-Machining-Nosalas-Hobby-Shop
    Sep 2009
    181
    Quote Originally Posted by Waynno View Post
    "UT" at Enter Next Command, then "Clocks"
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Jun 2004
    236
    Interesting, The older model 88 does not seem to have time display option, The newer
    one 88hs shows time, Neat feature if you are timing part runs, One odd thing, the 88hs
    shows 5034 "on" time, 24306 "run" time, so it appears something may have gotten reset at
    some point
    Wayne
    Feb 2006
    127
    Appreciate your comments.. Im pretty confident on the hours cause the owner was original and used the machine as support but never production.. Also he did know how to check the hours.. So im thinking I got a great machine with real low hours.. Doesnt mean its good for a machine not to run, but still it good to =know it wasnt abused..
    Thanks for all you comments !!
    Chips
    900
    Hi Chips--
    How's my favorite machine people doing these days??
    Neal
    Apr 2008
    1577
    Quote Originally Posted by chipsahoy View Post
    Hi Guys..
    Thanks Chips !!
    I only have one machine that hasn't needed a CPU replaced and shows the "real" hours.
    1996 4020 - 8922 hours of cutting time
    For reference:
    1997 5020A - 1022 hours (CPU replacement in Feb 2010 so the clocks were reset)
    If the hours are correct, I'd say it's pretty low.
    Mar 2006
    26
    My Fadal TRM has only six hours on it!
    Oh yea, I had to go through that SETP parameter routine last week.
    I assume that action zero'd everything out.
    The VMC 15, I didn't have time to look at.
    kap
    Mar 2009
    100
    I've got a 2005 4020 re-man with close to 30,000 hours power on and 18,000 cutting. 50,000 4th axis parts a year on it. Runs better than a maytag.
    Dec 2008
    441
    Quote Originally Posted by iess525 View Post
    Hello, im a beginner on my fadal machine. I start on this company/school in January the 3st.
    When i see in the clock menu, i see 262 hours power on, and 18 hours running!? its a 2002 year fadal machine So it is not used.
    What happen when i reset these numbers? or can i just reset the tool running time?
    Greetings from Robert
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Feb 2008
    547
    If I recall...
    Quote Originally Posted by Vegabond View Post
    ...correctly, they both can be zeroed at any time.
    Steve
    900
    Always keep in mind that the important issue is NOT the number of hours on a machine BUT how was the equipment used or abused!!!!!
    Neal
    Apr 2008
    87
    Our 6030 (1997) has pwr on 5056:58 and run 897:20 (seems a bit odd)
    Our 4020 (1991) has pwr on 30088:39 and run 22285:46
    Our 3016 (1995) has pwr on 7849:7 and run 2690:52
    Feb 2018
    3
    Re: How many hours do you have on your fadals
    HI,
    I am trying to check the number of hours ran on a Fadal 4020 and Fadal 40. They have a Fadal CNC Control 88. Every time I put in the "UT" command, the Offset Utility page pops up and it does not have the "Clock" command assign to a number. Any help on how i can get how many hours the machine has ran?
    This is what is displayed when I use the UT command:
    OFFSET UTILITY OPTIONS:
    1 TOOL SETTING CYCLE
    2 FIXTURE OFFSET SETTING
    3 TEST TS-20 PROBE
    4 TEST MP PROBE
    5 EXIT
    ENTER OPTION NUMBER _
    thanks
    Jan 2015
    417
    Your version of software does not have the Clocks, need a newer version
    Jan 2015
    417
    Clocks are only a reference anyways they can be reset to Zero at anytime. They are not an accurate use of the machine.
  1. FADALs hate-ers :)
    By Konstrukter1 in forum Fadal
    Last Post: 01-17-2010, 02:04 PM
  2. solidcam and fadals
    By BONSAIPICKLE in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-08-2008, 05:11 AM
  3. The new Fadals?
    By MojosMachine in forum Fadal
    Last Post: 04-15-2008, 11:45 AM
  4. Re-man Fadals?
    By hardrocker in forum Fadal
    Last Post: 06-11-2007, 07:47 PM
  5. Fadals in cells??
    By REVCAM_Bob in forum Fadal
    Last Post: 06-08-2006, 02:51 AM
