587,131 active members*
3,283 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cheap 1500W Chinese spindle, experiences?
Page 56 of 68 646545556575866
Results 1,101 to 1,120 of 1344
  1. #1101
    Feb 2010
    3447
    Quote Originally Posted by pistolknight View Post
    Hi folks,
    I just want to thank all of you hard working people for sharing your experiences with these spindles and VFD's. I firmly believe that without reading every one of the pages and pages of valuable information, i would not have been able to buy, set up and operate one of these chinese spindles correctly. Thank you.
    David
  2. #1102
    Mar 2006
    29
    Quote Originally Posted by BigKahunasigns View Post
    Hi, I have the 1.5kw chinese water cooled spindle and vfd setup from keling and it came with no info at all about how to set it up or anything. I found the online manuals for it and got it up and going, It runs and works great, all but the rpm on the vfd only climbs up to 11,520 rpms @ 400hz. I have checked all the settings that i know to check on the vfd but cant figure this out to save my life. Im new to the vfd and spindles so not sure what im doing with it all yet. If anyone has had this same issue or may know what im doing wrong please share helpful info. Thanks
    Michael
    Before you go changing Poles, check actual speed. The speed on my VFD shows about half of what it actually is. I got a laser tachometer & proved it. The VFD shows about what yours does, but the laser shows within 3RPM of 24,000.
  3. #1103
    Mar 2011
    Question poles
    Checked the pole settings p143, it was set for 4 (factory settings) I changed it to 2 pole, started it up and im getting the same prm readings, 11520. Seems nothing changed. I do not have a way of checking actual rpms at the tool but while cutting it sounds as if its cutting at the same speed as the 30,000 rpm router it replaced. If it is cutting at the right speed, im just wondering why it would be reading 11520 and not 24000.
    Thanks for your help with this, hope i can get it sorted out. If it wasnt for this forum i wouldnt have gotten it going this far... Thanks guys!!
  4. #1104
    Feb 2010
    3447
    Checked the pole settings p143, it was set for 4 (factory settings) I changed it to 2 pole, started it up and im getting the same rpm readings, 11520. Seems nothing changed. I do not have a way of checking actual rpms at the tool but while cutting it sounds as if its cutting at the same speed as the 30,000 rpm router it replaced. If it is cutting at the right speed, i'm just wondering why it would be reading 11520 and not 24000.
    Thanks for your help with this, hope i can get it sorted out. If it wasn't for this forum i wouldn't have gotten it going this far... Thanks guys!!
    whoa wait. You you claim your getting 11,520 rpm. Then you just say you have no way of checking it?
    Then you say its reading 11,520 and not 24,000.
    Do you think it sounds like half speed??. Rpm can be calculated mathematically as dave22 expressed:
    Motor RPM = (programmed frequency * mains power fequency) / number of pole pairs
    eg. For a 4 pole motor
    Motor RPM = (400hz*60hz)/2=12,000
    eg. For a 2 pole motor
    Motor RPM = (400hz*60hz)/1=24,000
    This would be a wise investment
    Digital Photo Sensor Tachometer
    Changing the poles from 2 to 4, or vise versa should net a significant change in noise. Video tape each starting @ 0 hertz and crank the knob to full. If you have the acceleration constant one should take twice as long to spool up (to max speed). If you change your poles from 2-4 or 4-2 and your not noticing any difference in time, noise, or speed. Something is up...
    I had mine set to 4 poles and it ran half speed. Changed it to 2 and she really toooook off! haha
  5. #1105
    Mar 2011
    Im just baffled at this, I recorded and timed the spindle spooling up on both settings 2 and 4 poles, same time spooling up, sounds and cuts the same both ways....Any ideas???? must be something i have set wrong or maybe wired wrong??? seems like there should be some change when changing the settings from 2 to 4 and back...
  6. #1106
    Mar 2011
    OK OK OK,,, Got it fingered out now!!! , PD144 Factory setting was still set for 1440,
    PD144 = 3000 (not 1440) this will get the speed display right, so it was runing at 24000...
    Thanks for all your help guys, I hope this will help others also.
  7. #1107
    Feb 2006
    202
    Dumb quick question:
    the 2.2kw spindles are listed as being three phase. Does the Hitachi output 3 phase power while only needing single phase input? Or do I need to consider a phase converter as well?
  8. #1108
    35538
    Yes, but you probably need 220V single phase.
  9. #1109
    Feb 2006
    202
    220 single phase isn't much of a problem. I've got a wash and dryer hookup very close to my garage. Just was afraid I would need to spring for a phase converter as well, since I'm quite a ways off from 3 phase service
  10. #1110
    Feb 2010
    3447
    Quote Originally Posted by gearsoup View Post
    Yes it uses 220-240V AC single phase input. (it also accepted 3 phase input).
    The VFD converts the single phase to 3 phase output for the spindle.
    The manual recommends 30 amp breaker, and 10 gauge wire to the unit. Hope that helps!
  11. #1111
    May 2006
    1469
    Quote Originally Posted by diyengineer View Post
    Mains power frequency has nothing to do with it.
    Could read,
    "Motor RPM = (programmed frequency * 60) / number of pole pairs"
    Or probably should read,
    "Motor RPM = (programmed frequency * 120) / number of poles"
    Motor RPM = (400hz*120)/2=24,000
    The fact that your mains frequency is 60hz is just a coincidence in this case.
    Our mains frequency is 50hz. Does not mean we get a different RPM from 400hz.
    Greg
  12. #1112
    Feb 2010
    3447
    Quote Originally Posted by Greolt View Post
    Should read,
    Motor RPM = (400hz*60)/1=24,000
    Greg
    Sorry i copied that quickly without fully reading it, figuring it would be right since its been talked about numerous times on the forum.. The constant should be 120, not 60. The math was wrong.
    The speed of a AC induction motors depends upon 2 things.
    A. Number of poles.
    B. Frequency of applied power to the motor.
    RPM= (120XFrequency) / (# of poles)
    Our 2.2Kw spindles are 2 pole, and the Hitachi VFD puts out a max 400Hz.
    (120x400)/(2)= 24,000 rpm max. Any speed can be calculated using this formula.
  13. #1113
    Dec 2010
    Unhappy Voltage doubt...
    I'm planning to buy a 1.5kw chinese air cooled spindle and got a doubt.
    In the country I'm in, residential phases are 115V and 3phase 230V = 3 x 115 V phases. Can I feed this spindle with this phases or I need 1 or 3 x 220V phases to feed it?
    Before asking here, I, ve asked a chinese ebay seller and he couldn't answer.
    Thanks, in advance!
    Alphonsus
  14. #1114
    Mar 2006
    29
    Quote Originally Posted by Alphonsus View Post
    I phoned my electrician friend. He said "220 three phase is called 220 because measuring from leg to leg will give you 220". That is what you have, it should work just fine.
    He did say some places have "high leg three phase". With that one leg to ground reads about 190 volts and the other two about 115V. You could still use it, but in a different circumstance you'd have to be careful if you had a 110V device that ran off one leg.
  15. #1115
    Dec 2010
    Thnks, Oaktreeman!
    In Brazil we also have 190 and 220V phases, but they're available to comercial and industrial uses only and, since you can feed these spindle matching inverters with 1 x 220V phase, this doubt has came out.
  16. #1116
    Jun 2006
    23
    Hello everyone. I have a great Request. I want to buy a spindle and an inverter on eBay, with 2.2 kW or 1.5kW power but must have collets ER16 or ER20 and do not know where to order. I'm afraid to order something to be damaged. We ask those who have bought something to me and guide me to a serious seller and quality products. Thank you very much. Regards.
    P.S. My English is translated by Google Translate.
  17. #1117
    Jan 2006
    88
    Quote Originally Posted by Nadiel View Post
    CTCtools.biz - collets made in china also - they both arrive and work...
    Probably not much use spending top dollar on collets for the spindles discussed here... Unless of course you have a mind to upgrade
  18. #1118
    Mar 2006
    29
    I bought a 2.2kw spindle with matching inverter from LoveHappy (Lovehappyshopping?) on eBay. No problems. Honest people and packaged well, BUT, everyone that orders from China takes a small risk of damage in shipping. Cross that bridge if you come to it.
    If you can afford it, get the 2.2. The larger collet is handy and the extra power can't hurt.
  19. #1119
    Feb 2010
    3447
    Quote Originally Posted by Oaktreeman View Post
    Agreed. I bought from love happy also.
  20. #1120
    Jun 2006
    23
    Smile
    Thanks for the replies, I would like a link (Lovehappyshopping) if possible (I want to order) and another link from where can I get a complete set of colets ER20, waterpump and radiator.
    Thanks again.
  1. Cheap and Simple ATC for Chinese Spindle
    By bogan in forum Spindles / VFD
    Last Post: 07-27-2018, 05:42 AM
  2. Chinese Spindle Experiences
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 03-29-2013, 02:02 AM
  3. Cheap chinese spindle modifications - Generic
    By speedydumpster in forum Benchtop Machines
    Last Post: 03-28-2013, 04:28 PM
  4. Porter Cable or Cheap Chinese Spindle?
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 01-21-2011, 08:15 PM
  5. Connecting a hitachi VFD to a cheap Chinese Spindle
    By zigmart in forum DIY CNC Router Table Machines
    Last Post: 11-26-2010, 07:35 PM
