587,366 active members*
3,515 visitors online*
Results 1 to 5 of 5
    Apr 2006
    23
    6h metric thread calculation
    Hi. I have just replaced my blown cranial gasket and am ready to try again.
    I am trying to figure out how to calculate the 6h tolerance position for a M24 x 1 thread and I cannot get my head around it. I find the wording very confusing and each time I (or the others I work with) try, I get a different answer.
    Could someone please explain in simple terms or even better, show me where I can find it on the net?
    Thank you...
    Mar 2008
    240
    Smellyfeet - The reason you can not find M24 x 1 6h is because it is not used.
    You have a 6H for the nut but not for the bolt. Bolt threads are 4h, 6g and 8g.
    I will list 4h and 6g.
    M24x1 4h: O.D. max 24.000, min 23.888. Pitch dia max 23.350, min 23.270
    Minor dia max 22.773, min 22.654.
    M24 x1 6g: O.D. max 23.974m min 23.794. Pitch dia max 23.324, min 23.199
    Minor dia max 22.747, min 22.583.
    As per DIN 13 T21
    Hope this helps you.
    Apr 2006
    23
    Hello Fella. Its definitely a 6h thread that is specified on our customers dwg. The Machinarys Handbook does go into some detail about calculating a "h" thread at the bottom of the 6g standard tables and lots of reference to 6h on the net but it is not too easy to understand.
    Smelly.
    Jun 2007
    3734
    Is the customer always right? Ask him/it/her for more specifications.
    I often find customers are after pie in the sky when all they needed was a sausage roll.
    Mar 2008
    240
    I am with neilw20. Go back to the customer. Someone on their Eng. staff needs to look up some charts. If they require an "h" limit - it should be 4h.
    . If there would be an 6h you could have a very hard time putting a 6H nut onto an 6h shaft since the nut could have 24.000 as its lower limit and the bolt could have 24.000 as the upper limit. Not a real possibility but still theoretical possible. That is why they have a 4h limit available for shafts. This would require grinding the thread. Still could be line to line (theoretical) but a better quality.
  1. Thread Depth Calculation and Constants
    By eliot15 in forum G-Code Programing
    Last Post: 03-27-2011, 12:40 PM
  2. Metric thread cutting on lb 15
    By mbm in forum Okuma
    Last Post: 02-05-2011, 02:47 PM
  3. metric thread
    By riverracer in forum Haas Visual Quick Code
    Last Post: 03-09-2010, 10:01 PM
  4. Acme Thread Calculation
    By Rally in forum MetalWork Discussion
    Last Post: 12-18-2009, 07:23 PM
  5. Metric Thread On LM8x14
    By pzzamakr1980 in forum Mini Lathe
    Last Post: 06-04-2008, 02:02 PM
