587,999 active members*
2,883 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > 4th Axis Feed Rate Problem
Results 1 to 11 of 11
    Nov 2010
    360
    Make sure you are using the latest post from Tormach (1.4). I had weird divide by zero errors and other issues with the G83 until I got the latest version. Version 1.4 worked just fine for engraving/rotary milling.
    I was also using the latest 7.1.4 release from the nightbuild directory....
    Oct 2004
    159
    The problem turned out to be a decimal point error in the Tormach post. Eric fixed me up with a new post, and the job ran perfectly.
    +1 for Tormach customer service!
  1. Z-axis feed rate
    By Richotech in forum Mach Software (ArtSoft software)
    Last Post: 08-03-2009, 03:13 PM
  2. Feed rate problem
    By Rene Nuñez Paz in forum Hobbycnc (Products)
    Last Post: 03-09-2009, 01:50 AM
  3. Mach3 with Taig Motor Feed Rate Problem
    By alt255 in forum Taig Mills / Lathes
    Last Post: 12-13-2006, 08:50 PM
  4. Feed Rate Overide problem
    By Moondog in forum Machines running Mach Software
    Last Post: 06-14-2006, 11:35 AM
