587,982 active members*
5,818 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Aluminum T-Slot Build Using Misumi Extrusion
Page 2 of 3 123
Results 21 to 40 of 56
  1. #21
    Apr 2010
    As mentioned above, I did manage to get the rail that had the worst baked-on "gunk" soaked in citric acid for a while. However, the garbage can I used had a hole in it, and the rail pierced the thin garbage bag while I was scrubbing it under water. So, the rail isn't as clean as it probably should be, but it's a lot better. If it proves to be a problem. I'll detach the rails and re-soak them later with a dedicated apparatus (probably a sonotube concrete form with some end caps fabricated). Let's get to the pics, though.
    First up, attaching the rail support beams (pictures 1 and 2). In true belt-and-suspenders fashion (redundancy for strength), I am using both a gusset and a mounting plate for this critical join. I finger-tightened the nuts, but in trying to wrestle the 7' long beams, I managed to knock them out of alignment. Fixable, but an irritant nonetheless. You can see the gap between the gusset and the bottom of the beam on the left side. I just didn't have the energy to fix that until I get an alignment tool.
    Note: these are GFS8-4590 beams with the 45mm sides milled "flat" (+/- 0.1mm max deviation). I'm sure one can get better tolerances, but not for anywhere close to the same price in my experience -- if you can find someone even willing to do the job. The bigger "cost" of using the milled surface, as mentioned previously, is that Misumi won't do certain types of machining on the milled surfaces. It's a trade-off, but I'm not regretting getting the milled surfaces, merely that I didn't get the ends tapped and the corner posts counterbored.
    The third picture shows the center legs installed, plus some extra structure I added to stiffen up the middle of the rails and ensure the width didn't vary too much over the length of the machine. These legs are pretty critical since they are needed to help control deflection. If I spanned the entire 2130mm, my maximum deflection with a 75kg load would be over 0.3mm. When I cut that span in half, the deflection drops to 0.04mm. I looked at several of the "commercial" (DIY+) offerings in this size/price class, and found instances where there were long spans with single extrusions, and I worried -- a lot -- about whether the deflection was going to eat away any of the supposed accuracy in the machines. Once you play around with the deflection calculators a bit, having long, unsupported spans will not look like a good idea. As it is now, I will watch what my results are to see whether I need to add more legs/structure in the future.
    Pictures three and four show how I used a some spare gussets to act as clamping surfaces to draw the beam in tight with the corner posts. Butt joints (e.g., screws, dedicated joint hardware) are good because they draw the pieces together. Gussets and mounting plates don't do that, so you have to add in the appropriate force to make a tight connection. This was about the only thing that went smoothly with this work step.
    Next to last, you can see the alternate use for the 4590 gussets. My eBay special SR30 rails and carriages don't have a compatible set of holes for any of the Bosch/Misumi extrusion series I am using. However, the Bosch 4590 gussets look like they will act as a good interface between the carriages and the gantry. The offset load shouldn't be a problem (well within spec, even with a pessimistic load for the gantry), but we will see how that bears out over time.
    Finally, the results of the acid bath. There was a lot of surface rust and some tar-like substance (baked-on grease?). The rail is working a lot better, but does have some surface pitting.
    More in a few days.
    Attached Thumbnails Attached Thumbnails left_beam_gap.jpg   right_beam_mount.jpg   middle_legs_installed.jpg   gusset_double_duty_1.jpg
  2. #22
    Sep 2005
    540
    You have a great thread going here, one of the best I have read in sometime.... I am looking to either buy or build a machine in the same size as yours so this is all very good info. Are you going to have a BOM available at some point?
    Thanks,
    Robert
  3. #23
    Apr 2010
    Quote Originally Posted by RTP_Burnsville View Post
    Thanks,
    Robert
    Thanks for the compliment. If there's interest, I can pull together either or both an "as built" and an "as I should have built it" BOM. Many of the parts will be specific to the gear that is anchoring my design, though (e.g., the mounting plates for the BK and BF brackets might not be necessary with the right attachment screw hole spacing on the BK and BF brackets). However, the basic X-axis frame will be reasonably generic or generalizable. After all, I'm basically merging half-a-dozen similar designs to suit my specific needs.
  4. #24
    Apr 2010
    XY Interface
    With temperatures a frigid 94 degrees outside (higher in the garage, er, um, shop), I was able to get some critical work done today on the parts that tie the machine base and X-axis into the gantry.
    Having done some more detailed design work based upon my current progress, I decided to have the bottom pieces of the gantry re-done to include holes where the drive bar should be located to minimize my chance of racking. previously, I had left this relatively open, but after getting hit by reality with where the BK and BF brackets need to be mounted, it became important that I get this positioning correct from the outset, rather than pick a spot, and then adjust later as I find out how much racking occurred at each new position. I had also originally thought about investing in a decent mill with DRO, but learning precision machining on what should have been production parts originally seems like an even more expensive idea. I'll continue to pay someone else to do that for the time being until I get this machine built.
    Machining Base Extrusions
    As previewed, above, the gantry will ride on base extrusions that are 384mm long, and that have 12mm nominal machining that is done "horizontally". In the first picture, you can see what "horizontally" means: there are two rows of holes, one in each t-slot. These are "clearance" or "through" holes, so they are sized up a bit from what the nominal dimension is. In this case, a 12mm screw is given a 13mm hole.
    In order to expedite assembly, I decided to take a risk and use locating pins instead of buying a Heli-Coil kit to tap the ends of the drive bar. Having never tapped a hole in my life, and having never used a Heli-Coil kit before, I'd rather go with something that depended a little less on my manual skills and more on my design skills. If need be, I reasoned that I could always try the Heli-Coil approach as "Plan B", but the locating pins were going to be cheaper, anyway, so they stayed "Plan A".
    If I had to do it over again, the right answer was to get the ends of the drive bar tapped from the factory (the HFS 4590 get a Heli-Coil insert at the factory since the hole opening is 12.5mm for an M12 hole, while the GFS extrusions get a "proper" traditional M12 tap with its 10.5mm hole).
    Locating Pins
    The locating pins were an interesting find in Misumi's catalog. There are pages and pages of options, but ultimately, I found one that looked like it would work with a 13mm base (to fit in the 13mm hole with no clearance), and that could be machined for a 12.5mm "nose". It also had the option for a tapped base (M8) that would work well to hold it snugly in place.
    While I needed to give the nose a few love taps with the rubber hammer to get it set correctly (that zero clearance thing), the nose fit snugly and securely into the opening in the end of the drive bar with a snug fit. It was then a formality to secure them with a screw, and then attach the drive bar to the gantry base with "double blind joint" hardware.
    For those who are reading averse, pictures 1 - 11 take you through the build step-by-step.
    Attaching to the Carriages
    Once I had the drive bar attached, it was time to attach the gantry base extrusions to the SR30 linear guide rails. This was done using Bosch 4590 gussets with the locating tabs pinched off. Since the 20mm screws I had on-hand weren't quite long enough to attach the gusset to the extrusion, I had to go up to a 30mm M8 screw and use a bunch of washers as spacers. It wasn't ideal, but it's pretty solid, even without the second set of screws in-place yet. A "post assembly" t-nut sits in the t-slot to round-out the hardware.
    This was a pretty nice solution (low cost, seemingly effective for the moment) to how to attach the gantry and the 4590 extrusion to the carriages. If I were using 4080 extrusion, then the native hole spacing in the extrusion would have matched the hole spacing on the carriages (mostly), but with the 4590 extrusion I had to improvise. I'm hoping this solution turns out to be a winner over the long-term.
    You can see this come together in pictures 12 and 13.
    Attaching the Ball Nut
    A drive bar wouldn't be much of a drive bar if it didn't drive, so the final step in today's build was attaching the drive bar to the "ball nut bracket" so that the ball screw could move the gantry along the X-axis. The drive bar has two M8 nominal counterbores spaced 50mm apart in the center of the bar (it is 1200mm long). In reality, since I was going with 110mm long screws that I had on-hand from a minimum quantity purchase, I probably should have just gone with wrench holes, saving a shekel or two. However, a couple of washers gain helped with keeping everything in-line.
    Note: unless you are looking to pay big bucks from a specialty dealer, longer screws do not come fully-threaded in my experience. Instead, there will be some amount at the end that is threaded, and the rest of the screw will have an unthreaded "shoulder". In the case of the 110mm screws, the threading was only about 25mm, leaving an 85mm long shoulder. There wasn't quite enough threading to snug the screws tight inside the counterbored holes, so the washers kept the screw head out of the counterbores. It's a tight connection, but we'll see how it holds up over time. This entire assembly is a critical one for the accuracy and durability of the machine, so if problems are going to come up, this will be an area that is on the list of "the usual suspects".
    Pictures 14 and 15 tell the story even better.
    Attached Thumbnails Attached Thumbnails gantry_base_01.jpg   gantry_base_02-locating_pin.jpg   gantry_base_03-inserting_pin.jpg   gantry_base_04-whack-a-mole.jpg
    gantry_base_05-symmetry.jpg   gantry_base_06-holding_screw.jpg   gantry_base_07-tightening_screw.jpg   gantry_base_08-drive_bar1.jpg
    gantry_base_09-drive_bar2.jpg   gantry_base_10-butt_joint.jpg   gantry_base_11-butt_joint2.jpg   gantry_base_12-attaching_carriages.jpg
    gantry_base_13-attaching_carriages2.jpg   gantry_base_14-attaching_screw1.jpg   gantry_base_15-attaching_screw2.jpg
  5. #25
    Dec 2010
    61
    Quote Originally Posted by Bear5k View Post
    That's balmy...great build...Thanks for all the advice before
  6. #26
    Apr 2010
    Quote Originally Posted by steeltoes View Post
    Your welcome. I spent over a year fussing with the design, and I'm still making rookie mistakes. Hopefully others can learn from them.
    Your build has certainly leapfrogged mine. It looks good!
  7. #27
    Apr 2010
    Danger! Danger, Will Robinson, Danger!
    As anyone who has spent time in product development knows (or if you've ever built/remodeled a house, etc.), the later the design change, the riskier and more expensive it is to make the change. With that in mind, my own current demon is from Automation Overstock in the form of a ball screw with 1900mm of threading and an effective travel of just south of 1800mm. With some creative realignment, this would extend my X-axis travel by over a foot (>300mm).
    I'm still playing around with drawings to see if my existing support blocks/bearings and attachment plates would work, but the cost of the change (minimum):
    - Ball screw: $500
    - Shipping: $50
    - New nut bracket: $100
    - Less whatever I could recover for my existing ball screw.
    So, so very tempting, but it is right at the limit of the flexibility I have for mounting a screw. Tough call.
  8. #28
    Dec 2010
    61
    Are you just trying to gain more travel? I ask my self is it really needed? Will the cost outweigh the return on investment? Is it someting thats fits better in your design? But yes you are correct...ordering more 80/20 and disassembly and reassembly has cost me a fair amount of loss time and $$...given the fact that mine was already built....
  9. #29
    Apr 2010
    More travel - definitely. My target material is Baltic Birch plywood, which comes in 5'x5' sheets. I could not find the right ball screws to get out to 5' wide, but I will be able to do a standard cabinet height (~40") in the Y-axis. My current X-axis, after the ball nut, is just short of making the full 5'. This would give me the 5' plus a fair bit of cushion without having to change any of the frame geometry.
  10. #30
    Dec 2010
    61
    If you need the full 5', which it sounds like you do, then a new ball screw is the best option for your application. As long as you are in the R&D state yet it would be cost effective for you to go with this route, which sounds like the best solution. Ball screws aren't cheap, sounds like your cost is a heck of a deal...IMO
  11. #31
    Apr 2010
    It's an OLD (1994) screw, but allegedly NOS (crated). It has some slightly odd machining, but I think it's doable. I'm still working through the tolerances and clearances right now. It's going to be a tight fit with my existing mounting plates.
  12. #32
    Dec 2010
    61
    Whats odd about the machining?
  13. #33
    Apr 2010
    It is machined for two BK brackets, but not the manufacturer's own BK brackets, as near as I can tell. At least not the ones they currently sell, but these products seem to have a LONG market lifecycle so I doubt the BK brackets have changed much (e.g., the 1994 ball nut mostly matches the 2011 ball nuts).
  14. #34
    Dec 2010
    61
    Got a photo of the brackets?
  15. #35
    Apr 2010
    See post #11.
  16. #36
    Dec 2010
    61
    IC...Is that your original bracket? What's the pitch of that ball screw? 1/2"/rev...
  17. #37
    Apr 2010
    Yes, it's my original screw and BK/BF brackets (came with the screw). The screw is 25mm in diameter with a 10mm lead (basically 1" and 2/5", respectively). I might be able to reclaim one of the BK brackets for the new screw if I pull the trigger. The BF bracket may not work at all (no snap ring machining in the new screw). Fortunately, Misumi sells new BK brackets for less than half the price of what Automation4Less shows as the price for a new NSK bracket, and the ones from Misumi have the exact same dimensions (no comment from me on that one, but it's a tempting coincidence).
  18. #38
    Dec 2010
    61
    Hmmm that is a coincidence...just like lipo cells for RC...there are like 3 manufactures that supply the world...It wouldn't suoprise me if they make them and white label them for someone else...Where do you get the Misumi extrusion from?
  19. #39
    Apr 2010
    Misumi's Us website: us.misumi-ec.com
    They have a 30% 'off' your first order promotion going on (limit: $150 rebated back to you). A lot of the stuff I am getting made has 'Made in Japan' on it, but the basic extrusion machining mostly seems to be coming from the US.
  20. #40
    Sep 2005
    540
    Have not scene much activity on this build and wanted to know how it was progressing? Any new and exciting updates? Would you happen to have a couple photos of gantry connection to the base rails?
    Have been messing with the Misumi DVD models and configuration tools, very interesting way to go.
    Thanks,
    Robert
Page 2 of 3 123
  1. Referral for Type III class I Anodize 6' long T-slot extrusion
    By owen hooker in forum Material Machining Solutions
    Last Post: 04-14-2014, 03:45 PM
  2. Misumi Site Extrusion Prices
    By newpatch in forum DIY CNC Router Table Machines
    Last Post: 08-21-2012, 10:10 PM
  3. Looking for 8020 T Slot Aluminum Extrusion in Canberra
    By bradeyk in forum Australia, New Zealand Club House
    Last Post: 08-04-2011, 11:58 PM
  4. Anyone used Polythene pad slides for T slot extrusion
    By cweeks in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2009, 12:29 PM
  5. T-slot Router Bed Extrusion
    By gotswrv in forum Want To Buy...Need help!
    Last Post: 07-11-2008, 02:16 AM
