603,946 active members*
3,253 visitors online*
Results 1 to 20 of 31
slowtwitch Emco 120p Rebuild 03-26-2011, 10:03 PM
rot Hello Pete, i have a... 04-08-2011, 08:11 AM
rot Hello Pete, anything new?... 06-08-2011, 09:23 PM
slowtwitch Lots, I have installed a 4 hp... 06-08-2011, 09:49 PM
slowtwitch Here's my progress ..so far.... 06-14-2011, 11:04 PM
slowtwitch It’s been a while since my... 07-19-2011, 12:11 PM
slowtwitch Some more progress.. I... 08-04-2011, 01:14 AM
LUCKY13 Nothing in the world wrong... 08-04-2011, 03:54 AM
slowtwitch I think i'm finally done... 08-16-2011, 12:55 AM
slowtwitch Hello everyone, I finally... 09-17-2011, 07:24 PM
LUCKY13 Thats pretty sweet, when you... 09-18-2011, 01:04 AM
Penprophet Spindle motor 08-14-2012, 04:40 AM
mike^3 Looking great! 11-30-2013, 01:27 AM
manthanpatel45 Re: Emco 120p Rebuild 10-30-2021, 09:41 AM
trainman4602 Hi Pete I’m new here and... 12-10-2012, 05:20 AM
slowtwitch trainman, a pm has been sent... 12-10-2012, 12:12 PM
Zahnrad_Kopf Pete, if you sent him the... 04-09-2013, 03:42 AM
slowtwitch I don't have any "magic... 04-09-2013, 02:46 PM
manthanpatel45 Re: Emco 120p Rebuild 10-30-2021, 09:46 AM
diyengineer Very awesome! 04-09-2013, 09:59 AM
mike^3 Awesome! How did you get the... 08-02-2013, 01:08 AM
slowtwitch I installed a 3 hp inverter... 08-02-2013, 04:30 PM
slowtwitch Hi folks, I just wanted to... 11-30-2013, 12:37 AM
mactec54 slowtwitch Looks to be... 11-30-2013, 12:59 AM
trainman4602 Hi Pete I want to wish you... 11-30-2013, 03:08 AM
mactec54 slowtwitch What did you... 11-30-2013, 07:09 PM
slowtwitch I'm using Andrew's board ... 12-01-2013, 01:24 PM
mactec54 slowtwitch Thanks for the... 12-01-2013, 02:56 PM
Pantechnicon Re: Emco 120p Rebuild 05-11-2015, 12:57 AM
slowtwitch Re: Emco 120p Rebuild 05-11-2015, 03:22 PM
Pantechnicon Re: Emco 120p Rebuild 05-23-2015, 08:08 PM
    Jul 2006
    367
    Hello everyone, I finally have my EMCO running I spent the last 5 vacation days learning this G code stuff..a 16 hour day was the average...lol. Setting the tool offsets for the drills in Machturn was the hardest. I really had a hard time setting the offsets for the drill bits. Although the drills had the same offsets, every time I called the tool number for a different drill, the offset would change. So I just did an M5, using the tool setting that worked and switch bits in the delay. Mach turn doesn't have a canned cycle for drilling and parting, so I kind of made up my own for each drill bit. Lastly, the turret is being operated manually. I'm going to try doing something in the future to get it working thru Mach.
    Anyway, without futher delay, My very first CNC program at work...
    [ame=http://www.youtube.com/watch?v=NfnCUv_4qqs]DSCN3859 - YouTube[/ame]
    pete
    Dec 2006
    839
    Thats pretty sweet, when you get the torret working its going ot be a very handy machine. CNC lathe is nice to have.
    Jess
    GOD Bless, and prayers for all.
    Aug 2012
    Thumbs up Spindle motor
    Hello- this is my first post. I got my 120P 2 days ago without the control box. If I understand correctly, most people change out the motor. Is DC or AC better?? What would be the min HP? I would rather use single phase if possible. What motor would be best?? What control board is best to control the frequency /speed of the motor through mach3??
    I really don't know what I am doing so any advice would be appreciated. I have 5 phase servo drivers coming, a flow control for the lubricant pump, a USB breakout board, and a control board for the power turrett which will also control the lubricant pump and the pneumatic collet closer.
    Thanks-- I look forward to joining this board.
    Mark
    Aug 2010
    190
    Looking great!
  1. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  2. Replies: 0
    Last Post: 11-22-2013, 07:49 PM
  3. Emco 120p grease??????
    By slowtwitch in forum EMCO Lathe
    Last Post: 12-07-2011, 05:26 PM
  4. WTB: EMCO MAIER EMCOTURN 120P
    By slowtwitch in forum Want To Buy...Need help!
    Last Post: 01-02-2011, 10:33 PM
  5. Emco VMC-100 Mill or 120P Lathe
    By dannyboysd89 in forum Benchtop Machines
    Last Post: 02-05-2010, 10:34 AM
