587,997 active members*
1,851 visitors online*
Page 103 of 107 35393101102103104105
Results 2,041 to 2,060 of 2130
  1. #2041
    Sep 2016
    506
    Re: OmioCNC report
    You ‘should’ use white lithium grease on your rails and screws, or better proper way oil. But they are exposed, and both those things attract chips like flies and they get stuck on. I’ve been using silicone spray lube on mine and it runs smooth, chips don’t get stuck and not had any issues whatsoever. Just be sure to do it regularly. There is also ptfe lubricant which will probably work better.
  2. #2042
    May 2015
    1422
    Re: OmioCNC report
    1. That's how I run mine, and it got rid of a bunch of noise issues which would bounce the USB connection after a couple of hours of spindle time.
    2. I've managed to snap a couple of the nipples and could never get a great deal of oil into 'em anyway. So I general put a few drops of machine oil along the leadscrews and linear rails and run each axis from one extent to the other a few times to get my lube on.
    Good luck with the reading - this thread has gotten somewhat out of control (about a hundred pages ago) and really, I - or some other volunteer - should ask to break it out into multiple related threads in one forum.
  3. #2043
    Dec 2016
    25
    Re: OmioCNC report
    Thx.
    Quote Originally Posted by Mmpie View Post
    ......... There is also ptfe lubricant which will probably work better.
    I was told not to use ptfe (Teflon) because " Avoid anything with Teflon in it. It will create Fish eyes in your finishes forever. It is almost impossible to remove once it is in there."
  4. #2044
    Dec 2016
    25
    Re: OmioCNC report
    Anyone of you made and use a spoil board for this machine? If so, a picture would be great. I want to lasercut one from MDF but can't quite figure out how to model it. I am planning to kiss-cut a nice pattern on it, straight horizontal and vertical lines, with 1 cm spacing. And a square ruler guide, or maybe rulers around the complete board, also kiss-cut into the MDF. And probably cut out long slots, so that the Alu T-slots are still usable.
  5. #2045
    Mar 2013
    319
    Quote Originally Posted by erik65 View Post
    What are you intending on making? Best solution will depend largely upon the general type of work you want to do.
    I generally use a consumable fixture plate made from SRBP. Advantage over MDF is that it’s not affected by water so you can use coolant without causing the MDF to swell and throw things out of level, disadvantage is just cost.
    For a lot of the work I’m doing at the moment, that works well for me - I can drill through into the bed and then tap and use that as a fixture point for the rest of the machining.
    If you check out my thread on my new router I’m building in the DIY section you’ll see a few different ways I approach work holding on the X6. Again, may or may not be of interest depending on your type of intended work.
  6. #2046
    Mar 2013
    319
    Re: OmioCNC report
    Something so simple
    Yes I got rid of the bellows too. The hiwin bearings and ball nut both have wipers on, so they should keep most the crap outside. Even with them removed Z travel is still prohibiting, particularly with typical jobber length drills.
    Off topic but just thought I’d share, this beasty turned up today
    Damn, want to adopt an overgrown kid?
  7. #2047
    Dec 2016
    25
    Re: OmioCNC report
    Quote Originally Posted by zeeflyboy View Post
    ...... Advantage over MDF is that it’s not affected by water so you can use coolant without causing the MDF to swell and throw things out of level.....
    Good info, didn't think of the swelling issue with MDF. I've never heard of SRBP, but what I do use every day is acrylic. That doens't swell and doesn't hurt cutters. So I probably just make two of the same spoil boards, one of MDF and on top of that one of plexi. Easy job with the lasercutter.
    Zeeflyboy, on page 8 you mentioned that you replaced the 3-wire spindle cable for a4-wire shielded one to get proper ground. What kind of connector did you use to connect this cable at the back of the control box? Original the connector is a 3-pin connector.
  8. #2048
    Sep 2016
    506
    Re: OmioCNC report
    Haha. If you’re not too far away and need something your machine can’t handle maybe you could have a play..
    I would recommend ditching the rear connector altogether and running the new cable and shield all the way up to the VFD. That then shields the important stretch of cable moving past the drivers and BOB inside the box. If you ever need to remove it, the VFD has screw clamp terminals so it’s easy peasy anyway. No need for connector.
  9. #2049
    Dec 2016
    25
    Re: OmioCNC report
    ..... I would recommend ditching the rear connector altogether and running the new cable and shield all the way up to the VFD. That then shields the important stretch of cable moving past the drivers and BOB inside the box. If you ever need to remove it, the VFD has screw clamp terminals so it’s easy peasy anyway. No need for connector.Sent from my iPhone using Tapatalk
    That might be a good idea too. In the meanwhile I did find the source for the 16mm connectors, thx to a comment on page 13 (yeah, I'm slowly reading through this complete topic! )
  10. #2050
    May 2015
    1422
    Re: OmioCNC report
    FWIW, Erik, I haven't upgraded the spindle cable. Once I grounded the machine frame, I didn't need to.
    There's a lot of good mods in this epic but bear in mind not everyone needed to do all of them. Collect the ideas, info, sources for kit etc by all means but I wouldn't go pre-emptively fixing problems before they show up for you.
  11. #2051
    Dec 2016
    25
    Re: OmioCNC report
    Yep, that's exactly what I'm doing, collecting all the interesting comments in a Word document. I grounded the frame yesterday and checked continuity from all parts, including the spindle, to the wall socket and that was OK. So I guess that I will only ground the VFD in the control box, that definitely is missing ground.
  12. #2052
    Sep 2016
    506
    Re: OmioCNC report
    The VFD is grounded via the case, on the bottom is a big metal plate. I actually removed my VFD from the black box because I was having big problems with the USB connection dropping out. It helped a bit.
  13. #2053
    Dec 2016
    25
    Re: OmioCNC report
    Ah, that is good news. :banana: Then everything on my router that should be grounded, is grounded.
  14. #2054
    Dec 2016
    25
    Re: OmioCNC report
    Are these the correct soft limits on the X6 (see attachment)? These are the settings in my machine that I bought secondhand.
  15. #2055
    May 2016
    29
    Re: OmioCNC report
    After your S***** M03 command, on the next line put in ‘G04 X**’
    G04 being wait and X being seconds, so G04 X2 would wait 2 seconds before moving to the next block.
    Finally got time to play in my shop with the G04 dwell command, just a note for others I found the "X" for time function didn't work for my machine, I found my CNC required a "P" representing pause. So I wrote G04 P5 on the line after my M03 command. This paused my machine for 5 seconds as the spindle spun up to speed. It worked great!
  16. #2056
    Dec 2016
    25
    Re: OmioCNC report
    How do you guys handle the maximum feed rate of the X6. According to the manufacturer's specs this is 4000mm/min (equals to 157 i/min), which seems so low to me. For instance a machine like the Stepcraft Q.204 has with 394 i/min more than double the feed. I'm asking because the Omio maximum gives me a 'headache' in CNCcookbook's feed and speed calculator, always running into the max feed rate.
  17. #2057
    Sep 2016
    506
    OmioCNC report
    It can’t run a lot faster. I went to 5000mm/min, some people are running it faster, but I had some binding issues. Probably because my ballscrews aren’t quite straight. They’re not supported very well either.
    Edit: it’s worth pointing out as well most wood routers have at least 10mm or usually higher pitch (20mm or 25mm) screws for speed, ie each rotation of the motor and screw moves the axis double or more the distance. The omio has 5mm pitch screws for torque and accuracy. Given how thin they are (and the already mentioned poor support) there’s only so fast they can spin before they start to whip anyway, the Y axis being the main problem.
    Quickly using a ball screw critical speed calculator, and this is assuming aligned proper rigid ballscrew mounts instead of skate bearings pressed into a piece of extrusion with questionable alignment, the calculator says a max rpm of 1160 on the Y or 5800mm/min feed rate.
  18. #2058
    Nov 2011
    19
    Re: OmioCNC report
    Please could somebody help me with how to get rid of the fault in the attached video (had to zip it for some reason I'm afraid). I tried a cut this morning and my machine has started stuttering in the y-axis; all other axes are fine. It's also a cut that I've made a few times before with the exact same settings. Thanks in advance.
    Attached Files Attached Files
  19. #2059
    Sep 2016
    506
    Re: OmioCNC report
    Quote Originally Posted by davekenyon View Post
    Can you stick it on YouTube? I’m on my phone so unable to unzip
  20. #2060
    Nov 2011
    19
    Re: OmioCNC report
    Bloody hell - didn't know I could... but I have!
    https://www.youtube.com/watch?v=hGd9...ature=youtu.be
  1. Report files
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 11-22-2009, 06:51 AM
  2. Machining Report
    By Tielegin in forum Esprit
    Last Post: 05-05-2009, 06:25 PM
  3. Fresh man report
    By ice in forum Commercial CNC Wood Routers
    Last Post: 09-28-2006, 11:45 AM
