587,608 active members*
3,607 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Steve Huck's Demon V8 version 1.5
Page 19 of 26 91718192021
Results 361 to 380 of 505
  1. #361
    May 2005
    394
    no its actually a train supercharger. as in locomotive
  2. #362
    Apr 2003
    1873
    Then I can say overkill
    I guess what ever floats ones boat.
  3. #363
    May 2005
    394
    if youre bored hit youtube and look for twin blower. you will find several cars that have been outfitted with 2 superchargers. as if one wasnt enough.
  4. #364
    Apr 2003
    1873
    That was interesting.
    I always really liked Pro Stock haven't been to the drag strip in decades, they have some real BA cars now.
    Did you happen to have time to post any machining pics of the blower pulleys on PhotoBucket?
  5. #365
    May 2005
    394
    No I didnt take any pics while I was machining the pulleys. its pretty simple stuff. I started with pulley stock and just whacked them off and did the bores and holes etc.
  6. #366
    Apr 2003
    1873
    Agreed, it is pretty straight forward with numerous way to accomplish it, still, always interesting to see how someone does theirs.
  7. #367
    May 2005
    394
    I made a set of bored jaws on the lathe then cut the blanks off a little long. then drilled thru it and faced one end. flipped the part then did both bores from one end and faced them to length. then I put them in a 3 jaw chuck on the mill, dialed it in and did the bolt patterns.
  8. #368
    Apr 2010
    486
    Quote Originally Posted by cforcht View Post
    Are you saying you can buy bar stock with the pulley grooves already cut in them? Where?
    Tom
  9. #369
    May 2005
    394
  10. #370
    Apr 2010
    486
  11. #371
    May 2005
    394
    No problem Tom. anything to help further the cause. I suppose if you REALLY wanted to someone could make the timing stock for the pulleys. but for the time you would have in it. its far easier and faster to just buy the pulley stock. unless you have gear hobbing equipment in your shop then it might be a different story. I do not though.
  12. #372
    Apr 2003
    1873
    That surprised me some, $20 difference between the two pulley stock, with SPI being the higher
    Misumi USA having for even less.
    Timing Pulley Bar Stock - MXL / XL / S2M / S3M / S5M | Mechanical Components for Assembly Automation - Misumi eCatalog
  13. #373
    May 2005
    394
    yes needless to say I didnt buy it there.
  14. #374
    May 2005
    394
    the blower drives are now complete. still need to make the fan and its adapter. now I can figure out the belt length and get them on order.
  15. #375
    Nov 2010
    360
    That is looking great! Have not started my build yet, but I'm seriously considering scaling up like you have.
    Looks like you have incorporated a starter. What are you using?
  16. #376
    May 2005
    394
    Quote Originally Posted by dbrija View Post
    Its a RS550 rc car motor. in theory it should turn it over. I have a 9:1 ratio over the motor. I only bought one of them in case is doesnt work and I need to use something else. I will post when I get to the point of trying it as to whether or not it does turn it over.
  17. #377
    Jan 2007
    76
    550 motor sits in well there.....scale look as well....I think your ratio should be well within the ballpark.
    If you can spin engine at 1000 rpm should be more than enough. One advantage of building larger scale engines is when you get to the electric starter as far as scale appearance is concerned. I have thought about using the brushless motors for smaller scale engines to try to keep the scale appearance. They require much greater reduction ratio though. Nice work ..........
  18. #378
    May 2005
    394
    If it works, I've kicked the idea around of making a shell to go over it that looks like a chevy starter.
  19. #379
    May 2005
    394
    started working on the blower scoop. had to change it to a 2 piece design because it was so deep inside. machining it was going to be a nightmare so I opted to make the 2 piece version instead.
  20. #380
    May 2005
    394
    here some more pics.
  1. Blower for The Demon V8
    By stevehuckss396 in forum I.C. Engines
    Last Post: 03-29-2020, 01:35 PM
  2. Steve's 2x2 CNC Router
    By Spk64 in forum DIY CNC Router Table Machines
    Last Post: 02-07-2015, 03:33 AM
  3. Demon V8 updates, getting them?
    Last Post: 02-08-2014, 06:25 PM
  4. Building a Little Demon V8
    By maxine in forum I.C. Engines
    Last Post: 06-21-2013, 06:21 AM
  5. steve pen
    By steve pen in forum Milltronics
    Last Post: 11-10-2012, 03:15 PM
