Originally Posted by
OkumaWiz
You could also do this if you are running in inch by using F1.5/25.4.
I see that you are running metric instead of our inch mode, but thought that you'd be interested to know that math can be used in the program virtually anywhere.
So leave the J value at 1 and use whatever is easiest for you for your F value.
One of the reasons to use the math is that the control will calculate out the pitch to a much smaller value (more decimal places) which will give you a more accurate thread. even if you are only off by .00005, it adds up to .001 error after 20 rev's or so.
Best regards,
