588,546 active members*
4,515 visitors online*
Thread: Hoss's G0704
Page 2 of 48 123412
Results 21 to 40 of 945
  1. #21
    Quote Originally Posted by Teyber12 View Post
    hmm you have had it a couple hours now and its not cnc'd yet?
    just kidding of course mate
    do you think that fixed drawbar will make it easier or harder to make it a power drawbar?
    cheers!
    That drawbar is held by a retainer that can be removed so it works like normal,
    The little 3/8 tit that you tighten to snug the collet sure won't take much torque.
    Manual guys need to take it easy.
    The retainer screws onto the spindle and lets you put a wrench on to tighten/loosen the drawbar without needing a spindle lock or brake.
    I'll replace all that for a power drawbar.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #22
    Jan 2010
    76
    Thanks a lot for the measurements Hoss. The only one that is very strange, is the spindle diameter at 3.063". The quill is just what it should be, but for that quill diameter, I thought the spindle should be 2.36" ??....which is what Grizzly and Lathemaster both advertise. Do you know what they are measuring at 2.36"? Thanks again.
    Quote Originally Posted by hoss2006 View Post
    1. 1.710 and 3.063 checked with calipers.
  3. #23
    Jun 2007
    3891
    Quote Originally Posted by madbee View Post
    i think he measured the lower part thats outside the head. the quill sleeve inside the head should be 60mm according to the grizzly spec.
  4. #24
    I just measured the exposed bits real quick last night, thought that was what you were looking for.
    My quill handle key went awol when I took it off for the move so I couldn't move it to expose the quill.
    It is 2.36. again with calipers.
    Hoss
  5. #25
    Jan 2010
    76
    Perfect, thanks Hoss.
  6. #26
    May 2008
    1185
    On the left side of the head their is that plastic splash shield. It hangs way down in the way and on mine if you open it it turns off the machine.
    I see no reason to leave it on, it is just one more thing to run into with the vice.
    Are you going to remove yours?
  7. #27
    It was gone before I took the mill out of the crate.
    I'll yank the guard limit switch housing shortly and bypass the switch.
    That's what safety glasses are for.
    Hoss
  8. #28
    Good to see the weekend, now I have time to get the mill up on the stand and out of the kitchen.
    For those who might be interested in how the G0704 stacks up to some other common mills,
    I put together a chart.
    You can check it out or download it here.
    http://www.hossmachine.info/forum/ya...-Mill.aspx#351
    Hoss
  9. #29
    Jan 2006
    123
    Interesting read Hoss. We will have to compare the few different BF20 designs out there now to see what parts are interchangeable.
  10. #30
    Jan 2009
    265
    Hey hoss, I thought you were gonna NC that RF45.
    I am a great admirer of your work, you should go big league one day and get Mach3 running on an old 3 phase vertical machine. (wouldn't fit in your cellar!!!)
    You walk the talk well!
  11. #31
    Jan 2009
    265
    I guess this means we aren't going to the prom together?
  12. #32
    Quote Originally Posted by D.L View Post
    Funny mate, Been busy with the new toy in between the Olympics coverage.
    Funny thing about the 3 phase vertical, they just put another old Bridgeport
    up for auction at work, I could have had it for $150.
    No way to get it home and into the basement.
    Someone got a good deal.
    Hoss
  13. #33
    Jan 2010
    76
    That's too bad. You could have put that to good use. Everyone's interests & situation gives them a different threshold for size/weight...regardless of price/performance. Thanks Hoss, btw, for providing the comparison of smaller mills on the market.
    Hoss
  14. #34
    I'll repost the link I gave for for Precision Mathews up the road from me in Pittsburgh.
    http://www.machinetoolonline.com/PM-MV-BenchMills.html
    They are now carrying BF20's, 25's and 30's in stock and ready to go.
    Still working on the specs but have free shipping with a stand and vise.
    Here's a couple vids for my G0704.
    Hoss
    [ame="http://www.youtube.com/watch?v=8sXH664Y78w"]YouTube- G0704 Standup.wmv[/ame]
    [ame="http://www.youtube.com/watch?v=vxHoSifZqss"]YouTube- G0704 Chip Guard Bypass.wmv[/ame]
  15. #35
    Jan 2010
    76
    I am not too familiar with this stuff, but does the .166" per crank turn on the Z-axis indicate a metric screw? I know most here are going CNC and don't care, but I was curious.
  16. #36
    Jan 2006
    123
    .166" would be 1/6 of an inch if you convert it to millimeters it is 4.2164mm.
  17. #37
    Jan 2010
    76
    Ahhh, it's the fractions. The answer is so obvious now that you explained it. Initially, I thought it was such an odd number. Maybe all mills have odd numbers. Intuitively, just expected something round for inch screws...like .2" per crank turn.
    Thanks.
    Quote Originally Posted by sfrankland View Post
  18. #38
    Jul 2008
    922
    its probably easier to train the children working on these machines that way.. sketch..
  19. #39
    Jan 2006
    123
    Thanks.
    With .166" you would need 6 turns per inch of travel and at .100" you would need 10 turns. And with the high school students I see coming out of school now-a-days counting to 6 is a challenge for most of them let alone all the way to 10.
  20. #40
    Jan 2010
    76
    I've actually got a BSME. I could help you with non-linear 3rd-order partial differential equations....but I never got the fractions thing...lol.
Page 2 of 48 123412
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-16-2024, 11:51 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
