588,338 active members*
4,951 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Cutting a 7.1" circle from 0.5" thick 6061 alum - End Mill "loading up"
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Nov 2013
    402
    If it helps, I just finished circle milling a 5" diameter hole with a 1/2" 2-flute endmill, 1.25" deep.
    I helical-milled it, dropping .050 per revolution.
    Ramping down on every pass is less stressful on the endmill.
    I was running the endmill at 3000 RPM, with a feed of 15 inches per minute (.005 per rev.)
    Full flood coolant, and brushing the chips out of the groove every three or four passes.
    It worked great.
  2. #22
    Jan 2007
    1332
    I trepan holes from 3" to 4.25" diameter in 1/2" 6061-T6 plate all the time on my 1100 using a HSS 1/2" 2-flute high helix end mill. Spindle @2700 rpm and feed 15ipm cutting depth 0.1" per pass with flood coolant. I typically blow the chips off using a compressed air gun. I used to trepan these holes on the lathe (shown below) using Val-cut 6mm trepanning tool but the Tormach does that job faster nowadays. I have bucket full of 1/2" thick aluminum plugs trepanned with this method.
    Don
Page 2 of 2 12
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Replies: 8
    Last Post: 03-24-2013, 01:13 AM
  3. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  4. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  5. What's the best 1/8" end mill for 6061 alum.
    By Cycle Start in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2008, 02:34 AM
