588,238 active members*
4,960 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > What's the best 1/8" end mill for 6061 alum.
Results 1 to 11 of 11
    Dec 2006
    25
    Hello all
    I need to use a 1/8" end mill to cut some intricate features. I have not worked with small cutters before. I have to cut an irregular slot 3/8" deep. What is the best manufacturer, speeds, feeds, and depths of cuts. The machine is a large knee mill, so rigidity will not be a problem.
    Thanks in advance
    Joe
    Mar 2008
    18
    What is the width of your irregular slot? If it is .125" then you may want to consider a 7/64" cutter.
    Jun 2004
    6618
    It may take you a little practice to figure out what will work best for you. I actually like the little Chinese made 3 flute EM's off Ebay sold by 800Watt. He doesn't comunicate very well, but I have ordered several batches of them from him and they always arrive in the mail a few days later. No trouble.
    With such small EM, you may be prone to break one or two before you get it right. You can get 10 of these for about $20 shipped or maybe less. These are 3/8" shanks. I can cut 30 of my 6061 parts out without any breakage normally on my home made bench top mill.
    I am cutting @ .04 DOC @ 3800 RPM and 35 IPM using coolant. I trim both ends of the 3/8" x 1" stock. Interpolate 2 1/4" through holes and peck drill 5 1/8" holes in the stock with these EM's. 4 to 5 minute part cycle at most.
    Lee
    Mar 2004
    576
    Quote Originally Posted by LeeWay View Post
    ... sold by 800Watt. He doesn't comunicate very well, but I have ordered several batches of them from him and they always arrive in the mail a few days later. No trouble. ...
    I purchased (a chuck) from him recently, and his communication is really really poor. I received extra unrelated items (pen torches) in the package, but he won't get back to me, so that I can send thos back to him.
    Jun 2004
    6618
    Actually I received a free gift the first time I ordered too. Can't remember what is was. Yes I do. It was a set of nails sets. I thought that was nice of him.
    I wouldn't worry about those little torches. He obviously doesn't.
    Lee
    Dec 2006
    25
    Thank you
    Hello
    Thank you for everyones input. To clarify yes the slot is wider than .125" its .140". It is a jr dragster wheel for my sons dragster that I have designed. I purchased the wheel blanks, now I am designing the custom center to cut out. There are a few places where the area is .140" wide in the tail fin area. Most of the areas I can cut with a .375" em. But the tail fin and pectoral fins will need to be done with a .125" em. Do you think I can make repetitive passes increasing Z depths(leaving finish stock on the walls) until I break through, then finish the walls? They are only .312" thick. I have a picture on the website I am developing, please feel free to take a look under "products" then "motorsports". BTW any ideas for the site will be greatly appreciated(please remember it is still under construction).
    Mar 2004
    576
    Leeway -- a gift would've been one. There were 10 or 12 of these pen torches in the box.
    Cycle start -- check out shars.com for endmills. I'm quite happy with the bang-for-the-buck with their M42 enamills (which I use with 6061-T6). I've never used their 1/8" sizes though -- just the larger ones like 3/8" and 1/2".
    Cheers,
    -Neil
    Jun 2004
    6618
    Do you have a link?
    Lee
    Apr 2003
    1873
    Cycle Start,
    These have worked very well.
    http://www.lakeshorecarbide.com/inde...TS&Category=35
    Mar 2008
    18
    Cycle Start,
    Ask 10 machinists for one endmill and you'll get 100 different answers. So here's a couple more one for the grab bag, http://www.yg1usa.com/ and http://www.harveytool.com/
    Good source's for odd-ball tools. Especially Harvey, they have endmills down to .001" diameter not that you'd need one that small.
    Good luck
    Dec 2006
    25
    forgot the link
    Sorry guys I forgot the link to my website. www.cyclestartcnc.com Thanks again for the em info. I need to order something soon. I might even redesign some features to accomodate larger end mills. Check out the solid model on my site.
  1. 1-1/2" Milled Pocket 6061
    By stang5197 in forum MetalWork Discussion
    Last Post: 10-11-2007, 02:45 PM
  2. Stamping letters in alum in CNC mill
    By clujan in forum MetalWork Discussion
    Last Post: 07-16-2007, 02:10 PM
  3. RFQ for 120QTY 5/8" Round Stock Standoffs 6061 Aluminum
    By mpstech in forum Employment Opportunity
    Last Post: 09-20-2006, 09:02 PM
  4. RFQ, water-jet type parts, 4" alum. brackets
    By sswitaj in forum Employment Opportunity
    Last Post: 09-05-2006, 03:09 AM
  5. RFQ - Alum. 6061 bracket
    By Msport in forum Employment Opportunity
    Last Post: 10-05-2005, 01:40 AM
