Originally Posted by
Ranscon
Looks like you have done some great mods. I also have the spotting laser. Did you wire it to the laser's electrical and if so, where did you tie it in? or did you use a separate power source? Also, I am adding air assist but have been trying to find out how much air is optimal? I have several large compressors but they are way too loud. I want to switch to a commercial aquarium pump. When searching, I have found posts that recommend everywhere from 9lph to 3200lph. That is just too big a difference for me to figure out what is needed. I want to have enough without overkill. I know 5-6 psi is plenty but cannot convert that to lph or gph which is how aqua pumps are measured. Trying to keep the budget to a minimum so don't want to buy a $150 pump if the $35 one will be sufficient.
Thank you for any info you give me on this, Jeff
