Mactec54 (or anyone else who can assist me in this matter),
I had posted in another thread
http://www.cnczone.com/forums/cnc-ro...cnc-forum.html that resulted in no help just yet. I have this same VFD and the matching water cooled spindle that I had purchased from Automation Technology, Inc. I have all the parameters set properly and your recommendations confirm that. I also am confident I have all the wiring correct (30+ years experience and understanding of wiring and electronics both industrial and residential). I can run the spindle fine from the VFD on manual mode. Where I'm having a problem is with how to setup my system to drive the VFD and spindle using Mach 3, through an Ethernet Smoothstepper (ESS), and a Gecko G540 drive when I've changed the VFD to PD001=1. I have the latest version of the ESS plugin and am running the recommended version of Mach 3. If you are anyone else can give me details on the setup in Mach 3 and the ESS plugin to get my spindle working through Mach, I would be greatly appreciative. When I set up according to the scattered (and often conflicting) info I've been able to find for setting up in Mach for this drive, I get zero reaction when trying to start the spindle. In fact, I can enter for example, 24000 in the spindle speed, and when I select the CW F5 button it resets to 0 and the button stops blinking. There is no error code as a result either. I appreciate any help that can be offered so I can get my machine up an running. (side note: I can manually jog XY&Z in Mach, but can't turn the spindle on).
