Originally Posted by
dsnellen
Mac, Thanks for your help. I now have 16/3AWG from the VFD to the Spindle. It's flexible and runs in the chain. Tomorrow I will connect the pin 4 to the spindle, reset VFD to factory default and carefully enter the parameters discussed earlier. The assumption is the spindle will spool up to its max rpm (24k?). For now, I am ok with turning the spindle on/off at the VFD. Oltimately, the goal is full Mach3 on/off, RPM control, but for now I will settle for VFD on/off at a known RPM. What variable(s) do I change to cause the spindle to run at 18k on start-up? Thanks. You have been a big help. And I have a new Southwire digital meter! :-)
CNCMan172. I will also cut off the excessive white wire in the VFD so it doesn't inadvertently come in contact with anything. Thanks for your ideas.
Dave
