588,711 active members*
5,431 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > What's going on with my motors? Mach3 problem vs noise?'
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Sep 2016
    13
    Re: What's going on with my motors? Mach3 problem vs noise?'
    Ok
    Hi Gerry
    I finally got the driver test to run. I had to open it as if I was running windows XP for some reason. I showed that everything was "excellent"
    I went over all my settings once more to make sure that I hadn't forgotten to save something
    Ran the machine and then : MAGIC it's working without a kink!
    You guys rock, If I could send you a beer I would!
    Thanks to everyone!
    Antoine
  2. #22
    It almost always says that, so that doesn't really tell you anything.
    You need to watch the kernel speed, to see how steady it is, and if it's close to what it's supposed to be.
    And also look at the line, and make sure it's flat with no spikes.
  3. #23
    Sep 2016
    13
    When I first tried the driver test it was spiking a lot but the kernel speed was constant
    The spikes went away other then the occasional small little spike here in there
    What exactly is too many spikes? and what does that mean?\\\
    Antoine
  4. #24
    Jun 2004
    6618
    The few little spikes are okay. I have never seen a perfectly flat lined Driver test. Flat lined means a human is not operational, but perfect for a driver test. The closer to flat line you can get on Mach 3, the better off you are. I am not certain, but I think the spikes are interruptions.
    Lee
  5. #25
    Apr 2012
    10
    I had a very similar issue where if i jogged my machine along either the x or y axis i had no issue but if i jogged both x and y together it gave almost a grinding sound from the x axis stepper. I tried a few things and swapping drivers etc on the X axis and still nothing. I then found a bad connection on the Y axis and corrected it and the problem went away and hasnt returned.
Page 2 of 2 12
  1. Noise problem causes Stepper motors to creep
    By Capnden in forum Stepper Motors / Drives
    Last Post: 07-11-2014, 07:38 PM
  2. RESOLVED! Mach3 MaxNC enabled = 1/4 speed motors , Disabled = no running motors.
    By BIWVince in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2013, 09:28 PM
  3. Motors Won't Turn But Make Noise
    By th3t1ck in forum CNC Machine Related Electronics
    Last Post: 01-01-2011, 11:44 PM
  4. Should my motors make noise?
    By thegimpster in forum DIY CNC Router Table Machines
    Last Post: 06-04-2008, 06:21 PM
  5. MACH3 and noise from stepper motor
    By timeout555 in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2007, 04:39 AM
