588,288 active members*
4,635 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 65
  1. #21
    Aug 2011
    I found chinese cutters dont give the same finish as a good quality cutter like a Cari-b-tool or similar. I would maybe plunge a little slower and that is the critical time for the cutter. Try misting with metho and little bit of kero to stop the metho drying out seals, You will see the difference in the cut also you can hear it when it is happy
  2. #22
    For cnc wood router cutters, usually the manufacturers offer 20 pcs around of cutters for using. For more higher quality cutters, OMNI also offer cnc router cutter list for your choice.
    Amanda Cheung from OMNI, www.omni-cnc.com,
    [email protected], Skype: omni-cnc
  3. #23
    Aug 2005
    91
    I have been using some of my 1/4" armana downcut bits. They seem OK but as a collet went missing I used my 6mm collet and the one that came with the machine. This wasn't one of the cheaper chinese ones but better quality.
    I like it more for sure. Quality of the cut is no issue but what I do like is even though its a down cut it is clearing thedust a lot better than the armana, no need to scrape it out, its letting the dusty have a good go at clearing most of it while cutting.
  4. #24
    OMNI CNC Router Details Photos
    OMNI CNC Wood Router Details Photos.
    The following is about OMNI CNC wood router basic model details photos. Hope you would get familiar with omni cnc wood router with the following information.
    OMNI CNC wood router Italy spindle works on the cylinder wood.
    Cylinder material device: rotary device. It is fixed on the working table, can be regarded as 4th axis of cnc wood router.
    OMNI cnc wood router motor part on 3 axis. Motors are with superior quality, rather affordable on the high temprature even 220 centi degree, with excellent working performance and lifetime comparing other cnc router manufacturer with 120 centi degree motor. Aluminium plate is with thicken one, rack and pinion ensure the high speed and precision.
    OMNI CNC wood router vacuum pump. This vacuum pump create the power to holding down processing material on the working table tightly.
  5. #25
    OMNI CNC - YouTube
    OMNI Workshop Brief View. In 2014, OMNI factory will be double size as the current workshop, OMNI office will move to a new building which is at 500m2. Big step for OMNI!
  6. #26
  7. #27
    OMNI applied for Bureau Veritas(BV) Assessment since Nov.2013, and the assessment activity carried on by the end of Dec. 2013. OMNI finally get Assessment Certificate on 7th, Jan. 2014 for products of china cnc router, cnc plasma cutting machine.
    Brief introduction about BV: Founded in 1828, Bureau Veritas is a global leader in conformity assessment and certification services in the areas of quality, health and safety, environment and social responsibility (QHSE). We are a trusted partner of our clients offering services in 8 global businesses and developing innovative solutions to reduce risk, improve performance and promote sustainable development.
  8. #28
    Re: Omni CNC ordered.
    How we delivery your cnc router, laser, plasma cutting machine goods? What we do before delivery your goods? How we care about your goods? See below photos.
    1. Smearing engine oil on linear guide, round orbit, spindle, rack of china cnc router, etc
    Attachment 230850
    2. Using bubble wrap to wrap control cabinet, spare parts ordered.
    Attachment 230852
    3. Using stretch film to cover machine body and spare parts etc
    Attachment 230854
    4. Bridge crane lifting machine and seat to the wooden case plate covered with felts and supported with steel tubes.
    Attachment 230856
    5. Fixed machine with wooden block beside of machine feet.
    Attachment 230858
    6. Covering PE bag to machine body for double protection from humidity, Tighten this PE bag with stretch film again.
    Attachment 230860
    7. packing wooden case
    Attachment 230862
    8. Fixed wooden case with packing strap tightly.
    Attachment 230864
    9. Mark on wooden case and lifting wooden case to container or truck with shipping note.
Name:	DSC_0230_%u002525E5%u00252589%u002525AF%u002525E6%u0025259C%u002525AC%u002525E5%u00252589%u00252.jpg
    We pay attention to every detail when delivery goods to you, this ensures you could receive our affordable cnc router, laser machine, plasma cutting machine safely.
    Now email us to get the free quotation!
  9. #29
    OMNI CNC Wood Router Workshop Brief View.
    Attachment 235708
  10. #30
    Every child loves "Pleasant Goat&Big Big Wolf" in China. Besides the carton they watch, even every new year, there is movie about "Pleasant Goat& Big Big Wolf", lots of children go for watching for celebrating new year.
    Today,we make a mold of Pleasant Goat with Styrofoam block by cnc wood router.
    Block diameter: 180mm,
    processing speed:8000mm/min,
    Processing Time: 15 min
    Related Product Link: Foam CNC Router
    Program File Photo:
    Attachment 236714
    Sample Work:
    Styrofoam block shaping by OMNI china cnc router. Block diameter: 180mm, processing speed:8000mm/min, it takes 15 min to complete the work. EPS Shaping CNC Router-EPS shapingcnc router|pattern making router|mold cnc router
    Styrofoam(Polystyrene) material often be used as lost foam for mold making. Such molds usually used in furniture, gift, industrial part etc. CNC wood router could shape styrofoam block quickly at high precision for mold shaping.
  11. #31
    Modillion-an ornamental block or bracket beneath the corona or similar member of a cornice. OMNI china CNC router process it at speed of 6000mm/min, whole process takes 2.5hr for styrofoam material, if is wood material, it takes 3-4hr according to the wood hardness and pattern. Product Suggest: OMNI RD Series_Rack CNC Router_cnc wood router
  12. #32
    Leaf Pattern Modillion Engraved by OMNI CNC Router. Processing Speed: 8000mm/min, it takes 2.5hr to work on it. If it is wood material, it takes 3-4 hr.
  13. #33
    OMNI CNC router engrave 3D lotus on aluminium plate. We use flat end engraving bits, 30°,0.3 size. It takes 3 hr to complete the work.
  14. #34
    Art Type Work Made by China CNC Router from Nick Sokolov in Australia
    Nick Sokolov is a professor in a Lab in Australia. He uses OMNI4040 CNC Router to make some art type work. The material he uses are acrylic, plastic, wood etc.
    That art type work is for his air vehicle mold. He uses mini cnc router OMNI4040 to cut the acrylic. The control system he uses is MACH3.
    See following photos about art work and OMNI4040 mini cnc router.
    Attachment 249964
    Attachment 249966
  15. #35
    OMNI CNC Router Customer Review
  16. #36
    The modillion engraving video is offered by OMNI cnc wood router client.The client uses wood material to work on cnc wood router for modillion engraving.
  17. #37
    OMNI laser engraving and cutting machines are mainly for non-metal material by higher precision processing way,suitable for vector cutting, raster engraving, sign making, displays, sheet fabrication, textile fabrication and cutting, name plates, outdoor advertising and more.
    Today, we introduce OMNI1326 Laser machine, which could fit 80, 100, 130, 150w laser tube.
    Attachment 254360
    The following is 30mm acrylic cutting video.
    There are several tips:
    Speed: 0.5mm per second
    Power: 65% for power, use at least 130W laser tube
    attention of air out volumn
    Be notice that do not let laser burn the acrylic
    Good quality lens and mirror is important
    Check out for the laser cutting machine for more features and parameters.
    Sample:
  18. #38
    From the video, you can see what OMNI laser machine look like. OMNI laser engraving and cutting machines are mainly for non-metal material by higher precision processing way,suitable for vector cutting, raster engraving, sign making, displays, sheet fabrication, textile fabrication and cutting, name plates, outdoor advertising and more. For more info, check out: Laser Machine-china laser engraving machine?china laser cutting machine
  19. #39
    OMNI CNC cutting MDF. The video is from OMNI cnc router user.
  20. #40
    Newel posts processed by OMNI cnc router. This kind of cnc router could work on stair parts, such as turned and box newel posts, handrail, baluster, stair moldings, wood carving, relife sculpture i e. Check out OMNI cnc router view: Review-cnc wood router feedback/omni cnc, and for machine, click the link: OMNI1325 CNC Router With Rotary Device_Custom Made_cnc wood router
Page 2 of 4 1234
  1. OMNI 1325 Ordered
    By swarfmeister in forum Chinese Machines
    Last Post: 10-28-2016, 08:14 AM
  2. OMNI-CNC 1325 on its way!
    By Jzarski in forum Chinese Machines
    Last Post: 10-28-2016, 08:09 AM
  3. 1325 machine ordered from Omni cnc
    By jbobrout34 in forum Chinese Machines
    Last Post: 08-22-2015, 02:38 AM
  4. OMNI CNC Profile
    By omnicnc in forum Omni CNC
    Last Post: 03-30-2012, 08:00 AM
  5. OMNI CNC
    By omnicnc in forum Commercial CNC Wood Routers
    Last Post: 02-11-2012, 05:09 AM
