603,383 active members*
3,711 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > FineLine Automation > Saturn 4'x4' My Second Build the first time with Clearpath Servos
Page 2 of 3 123
Results 21 to 40 of 47
  1. #21
    Mar 2017
    164
    Re: Saturn 4'x4' My Second Build the first time with Clearpath Servos
    @Whitewolf , it certainly looks like there's better contact on the gear rack now . The pinion looks as though it's awfully close to the frame
  2. #22
    Mar 2017
    72
    Quote Originally Posted by difalkner View Post
    Is the pinion rubbing against the frame (last photo)? Ours is about 1/8" away from the frame. I think Nate is working on spacers to retrofit the first Saturn machines or deeper racks for the newer models but I'm not aware of a release date - thought it was in effect for the machines going out the door now, though.
    David
    Nate will have to comment on that, there is about 1/8" on one side and even less on the other, there does not feel like there is any play in the pinion or pulley system.
  3. #23
    David
    David,
    We swapped out the washer under the pinion for a split lock washer. That moved the pinion inward a bit. It's about 3/64 from the edge.
    Fine Line Automation
    www.finelineautomation.com
  4. #24
    Quote Originally Posted by MajorTendonitis View Post
    During testing we determined we could move it inward slightly because we dramatically reduced the in-out flex in the pinion plate.
  5. #25
    Nov 2014
    714
    Quote Originally Posted by FineLineAuto View Post
    That makes sense... can't do that with mine.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  6. #26
    Oct 2016
    236
    Good to hear that the drives seem solid. I'm looking forward to reading about the build!
  7. #27
    Mar 2012
    103
    David,
    Nate,
    So is that supposed to be our solution? Still seems like a wider rack would be be better...
  8. #28
    May 2012
    114
    The ideal solution would be to space the rack out with some flat stock like cncrouterparts does vs the spacing the pinion gear out more. It's basic engineering 101. The flat bar would have much more contact area than the washer behind the pinion gear.
    This wouldn't be a fix to me.
    Quote Originally Posted by beltramidave View Post
    Nate,
  9. #29
    Nate,
    We are still planning on moving to a wider rack. We have 3/4in wide rack being manufactured, which should give you more contact area than just using a spacer.
    Right now though, the current 1/2in wide racks function fine. I am also still planning on offering the spacer to those that want it. The spacers are in transit and should be available in about 2 weeks. We have sized the screws on the Saturn machines long enough that you should just be able to unscrew the screws part way, drop in the spacers, and tighten back up.
  10. #30
    Quote Originally Posted by ericclinedinst View Post
    Also, note that the split lock washer was not designed to move the pinion closer. It was designed to replace a flat washer to reduce the contact area of the washer to just the inner race. The flat washer extended out one the bearing cover and in some instances caused binding.
    In this case, the split washer just happens to be thicker and moved the pinion inward slightly.
  11. #31
    Oct 2016
    236
    Nate,
    With the new steel gantry, how are the wires routed from the main cable chain to the second gantry drive motor? I did not see any pass-through holes through the gantry beam, and previously I would have routed them through them middle of the aluminum extrusion.
    Robert
  12. #32
    Mar 2012
    103
    Quote Originally Posted by DDgitfiddle View Post
    Nate,
    Robert
    Robert,
    I just ran along side the cable chain that is for the Z axis. Worked just fine.
    Dave
  13. #33
    Nate,
    Robert
    Robert,
    The gantry has a cable tray that runs the entire way across the back of the gantry. It has room for both the cable chain and routing cables across the gantry.
  14. #34
    Apr 2003
    540
    Looking forward to getting and installing the spacers. I'm not having any problems since I replaced the R&P drives, but improving the rack contact has been on my list of needed improvements. Thanks for the update.
    Marc
  15. #35
    Mar 2012
    103
    I too would like the spacers when they become available. Thanks Nate.
  16. #36
    Nov 2014
    714
    Ditto!
    David
    David
    Romans 3:23
  17. #37
    Mar 2017
    24
    Ditto!! ( X 2)
  18. #38
    Dec 2012
    108
    Me too on the spacers.
    Ward in San Diego
  19. #39
    Jan 2017
    14
    Same here. Or better yet the wider rack.
  20. #40
    Mar 2017
    72
    Not much to update at the moment, Just finished my 3D printer build now to program the firmware then its back to the CNC build
Page 2 of 3 123
  1. Can two clearpath servos be used to power one axis?
    By Dangle_kt in forum DIY CNC Router Table Machines
    Last Post: 02-17-2025, 06:24 PM
  2. 2nd Build (first) - Saturn CNC 2'x4'
    By difalkner in forum FineLine Automation
    Last Post: 11-11-2017, 12:56 AM
  3. Clearpath Servos for Tormach?
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 05-02-2017, 01:31 PM
  4. Saturn 4 X 4 build
    By sybilsurf in forum FineLine Automation
    Last Post: 03-19-2017, 01:47 AM
  5. Some advice and opinion on Clearpath servos
    By KennyPowers in forum Servo Motors / Drives
    Last Post: 09-11-2016, 09:22 PM
