603,310 active members*
2,326 visitors online*
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Aug 2009
    116
    Re: Siemens 810 on Chiron FZ12
    Hello,
    can you provide a Machine Number?
    You tell tht eye button does not help.
    If this is correct I think you have a faulty Eprom?
    I can check the Eproms here.
    Wait for your reply
    Regards
    Thomas
  2. #22
    Jan 2013
    84
    Quote Originally Posted by servtech View Post
    The original message translated means "data parity error monitoring" giving the fault addresses. Could have been battery, but as you changed it, it's unlikely unless you lost the memory.
    Do you have a parameter data backup you can upload?
    Good day, battery is OK. I have the parameters but cant upload them because machine is stuck on the initializing screen and the "eyeball" button doesnt work. Also RED led on the back of CPU card is ON (if that means something).
    Any help would be very appreciated.
  3. #23
    Jan 2013
    84
    Quote Originally Posted by tld70 View Post
    Hello,
    Wait for your reply
    Regards
    Thomas
    Good day and thank you.
    Machine number is : 471-09
    Is it normal that the RED led is on on the CPU card?
  4. #24
    Aug 2009
    116
    Hello,
    the red LED will be on ehen the CPU is not running,
    If you press the Eye Button and switch on you will still have the alarm?
    If yes, one of the Eprom Module is defect.
    May this module you showed, the 2 eproms on the CPU Card or the module on the buttom
    where the 3 small insertions are located.
  5. #25
    Jan 2013
    84
    Hello,
    I only see "initializing and testing" screen no alarms
    Do you have a photo?
    Thank you.
  6. #26
    Aug 2009
    116
    Hello,
    I do not have a photo,
    You hav a defective Eprom module or the CPU card will be defective.
    The problem is, I live in Germany
    that means it is not easy to help you.
  7. #27
    Hello, Mr.Thomas,
    i own a chiron fz12w ga2 1991- number 107-45, and the battery was weak and i lost all parameters,
    i contacted the chiron and all they had was a files tea1 and tea2,
    do you maybe own some files that can put the chiron back to life ?,
    Best regards,
    Dejan
  8. #28
    Aug 2009
    116
    Hello Dejan,
    I have the S5D file if you have Step5 it is no problem to load this.
    Give me your Email and I will send the files.
    Best regards
    Thomas
  9. #29
    Hello Mr. Thomas
    My email is: [email protected]
Page 2 of 2 12
  1. Chiron FZ12W High speed Siemens 810m error codes
    By efret in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-15-2022, 08:36 PM
  2. Chiron FZ12 with siemens 810M . Softkeys not working.
    By terrycoughlan in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 04-09-2015, 07:06 PM
  3. Chiron FZ12 W Fanuc 21MB
    By singist42 in forum Fanuc
    Last Post: 04-08-2014, 04:10 PM
  4. 1993 Siemens control Chiron Machine
    By warrenb in forum SIEMENS -> GENERAL
    Last Post: 09-05-2012, 01:06 PM
  5. chiron m/c
    By praveen224 in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2006, 12:32 AM
