http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Nope - I've had two of them, and the bodies wobbled on both. It does not affect the functionality in the slightest. The shank is simply threaded, and screwed into the body - no real effort made to make it perfectly concentric or square.
WildHorse is a one-man "hobby" operation - he makes every one of those things himself, so they're not perfect, like a Renishaw.
Regards,
Ray L.
I'd tell them to keep it, glad I never spent my money on one let alone 2.
Get the Tormach Passive Probe, looks like better quality and folks seem to like it.
Passive Probe
Or you can go old school and use these to find your edges.
Edge and Center Finder, Fisher - LittleMachineShop.com
Edge Finder, Electronic - LittleMachineShop.com
Hoss
Care to share how that is done? Nothing in the instructions or any obvious way from looking at it. It is just a Delrin type arbor with three brass posts resting on the 6 balls. The tip just screws into it. A spring on the back to keep pressure on the posts. Maybe the PCB could be adjusted, but this one is just pressed into place and possibly glued to the bottom.
You can read here if yours is the same.
http://www.wildhorse-innovations.com...-Alignment.pdf
I'll stick with my good ole edge finder.
Hoss
Yep, thats the one. Thanks Hoss. Will take a good look at the new one and give it a fair shake before I judge it. This is the type of document that either needs to be included in the box with the probe, or at least a piece of paper with a link to the file.
On a similar note, I am using a Z-plate that is active Low. This type of probe is a NC type contact and is an Active High. Wonder would it be possible to code the auto corner edge finder script to watch for a change of state of the "OEMLED" rather than its current configuration. I would have to ditch the part of code that looks for a grounded plate (already have it quasi disabled by changing the value to 1 for it to work with the probe). Any ideas anyone? that way I could use the same input for my touch plate and this probe type without having to wire another input. This is not much of an issue since I will be going with a second BOB soon to run my spindle after I add the 4th axis
That would be easy enough to do, but you'd lose the protection of sensing whether the probe is active at the outset. That means, if the probe is not connected or otherwise not operating properly, the macro will be quite happy to go ahead and attempt the operation, which is likely to result in a broken probe, as it drives the tip right into the part or vise. Much safer to just go into Ports&Pins, and flip the PROBE input pin polarity. Or, add a little logic to invert one of the probes, and AND them so the PROBE input goes active when one probe goes HIGH or the other goes LOW. That could be done with a single transistor.
Regards,
Ray L.
Go to page 131 of the MachStdMill user manual found here: http://www.calypsoventures.com/msm_d...r%20Manual.pdf There's a schematic for building a little circuit to use both a NO touch plate & NC probe on the single probe input into Mach3 ..
I'm not an electronics guy by any stretch of the imagination, but I do a little tinkering here & there and was able to build this circuit myself with parts that came from local electronic retail stores near me.
Works great because both probe & touch plate stay plugged in all the time and either is available for use when needed. And at least on the MSM probing screen all you have to do it move the probe tip a bit by hand and you get a light to confirm it's active, avoiding the possibility of destroying it as described by Ray.
gdmarsh
Thanks, that makes sense. Yup, first build--hence the reason things that may be obvious when I finally get to that point are just mental conjecture until then. In the meantime, just need to finish a couple more parts to Hoss' plans before it's time to break down the mill, roll up my sleeves, and see what I don't know.
Not to steal space in Hoss' thread, but this discussion of the Econo-probe is very timely, as I've been looking at purchasing one. Now I'm seriously thinking of pursuing Plan B: converting one or both of a pair of Renishaw probe heads I picked up on eBay for $0.99 plus shipping. :idea:
It's a regular 7x10 lathe head bored out on either end to fit the bearings for the 5C spindle.
The spindle needs threads cut on the end for a pair of jam nuts.
Hoss
One of these collet fixtures.
5c Precision Spin Index Fixture Collet for Milling New | eBay
Hoss
Thanks! a bit of an old one but thanks.
Hoss
Been busy this past several days as you can see here.
http://www.cnczone.com/forums/1232119-post1029.html
Now I can get back to the powder cup funnel and new super capacity version.
Hoss
Aluminum spring bed with tempered glass on top, works great on my prusa.
Hoss
