588,627 active members*
5,762 visitors online*
Thread: Hoss's G0704
Page 220 of 344 120170210218219220221222230270320
Results 4,381 to 4,400 of 6871
  1. #4381
    Quote Originally Posted by ddragon View Post
    Hi Hoss
    If I can change the subject for a second, been going over your g0704.com website, love it btw... And I'm in the process of building a high tension draw bar. I just bought a used air cylinder with a 3.25 bore and 1.5 inch stroke that should do the trick. But damn, it's heavy. How much does yours weight and will it damage anything if it's too heavy?
    Also you mention that this version is easier on the spindle bearings. Is that because the cylinder is attached with springed bolts and it moves up as it pushes?
    Thanks, and keep up the great work.
    Thanks!
    If that's a single stage cylinder it's only going to give a little over 800lbs @ 100psi, not enough even for light duty.
    Ideally for the g0704 you'll want 1200 available for LD and 1800-2200 for normal use.
    Don't know what my self-made 3-stage cylinder weighs but the whole power drawbar weighs 7lbs 13.6 oz, just checked.
    Yes this PDB doesn't push down on the drawbar and bearings, it technically squeezes the bellevilles.
    On another note the SC cup is half way done.
    Hoss
    Attached Thumbnails Attached Thumbnails 101_2540_800x600.jpg   101_2531_cropped_711x600.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #4382
    Jan 2010
    93
    Quote Originally Posted by hoss2006 View Post
    Thanks!
    Hoss
    Hmm. I took a look at the videos again a few times. I can't see how it squeezes? Seems that the piston is still pushing down/out, which makes contact with the top of the spindle, then because of the springed bolt it pushes the entire cyclinder section up?
  3. #4383
    Yeah the cylinder pushes down, it makes contact with the top of the drawbar.
    Because the mount is not attached to the mill head the cylinder takes the path of least resistance and lifts the mount till the plate makes contact with the bottom of the tophat that the bellevilles sit on.
    As the cylinder continues to push down on the drawbar and up on the bellevilles the path of least resistance is to compress the belleviles.
    When the bellevilles compress, the drawbar moves down opening the collet.
    The 2 springs are really just to keep the pdb mount pushed down when the drawbar is released so the plate won't rub the tophat.
    Hoss
  4. #4384
    Jan 2010
    93
    Ok. I think I got it. Looks like there is a lip on the lower horizontal bracket that fits under the washers? So that basically holds the washers in place while the cylinder pushes down to compress them.
    Nice!
  5. #4385
    Jun 2008
    475
    Hoss,
    Awesome job on these cups, not just the actual parts but also the imagination to design and produce them !!!
    About a year ago, I bought the same Craftsman powdercoat gun based solely on your use and opinion of them. I've been very happy with it except for the OEM cup, too small, hard to clean out and change powders and leaks powder badly if I don't tape up the cup.
    Sorry if I missed it but, do you plan to sell some of the XC cups ? I'll buy several to start with if so.
    Great work, as always, thanks,
    Steve
  6. #4386
    Thanks very much Steve, check back in a couple weeks.
    I have it tied up making parts for a new printer but then I'll get back to making some extras.
    [email protected]
    Hoss
  7. #4387
    Jun 2008
    475
    Thanks a lot Hoss, will do. I appreciate your willing to make some extras for sale, that's great ! Talk with you then.
  8. #4388
    Yeah, it takes a day to make one and a couple days to be sure the glue cures.
    Hoss
  9. #4389
    Nov 2004
    306
    Hoss
    Very nice. Are you doing anything to seal the print to make it air or water tight?
    Checkout my new Tech Blog! http://xnaron.com
  10. #4390
    Quote Originally Posted by Xnaron View Post
    Yes I coat inside and out with the Weld On #3 cement, it's very watery and seals it up nice and leaves a shiny smoother finish.
    Video shortly of all 3 cups spraying powder in my kitchen.
    Hoss
  11. #4391
    Wahoo they work! Better than my originals but I imagine that's because of the o-rings I use in these.
    Do need to mod the SC a little, it's a bit tight but still went on and off like I expected.
    Now to get making some ally stepper mounts to powder coat for real.
    Hoss
    [ame=http://www.youtube.com/watch?v=poNm9dsoQ-k]Hoss Powder Coat Cups Demo - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails 101_2566_cropped_665x600.jpg   101_2580_cropped_700x600.jpg   101_2585_cropped_551x600.jpg   101_2590_cropped_533x600.jpg
  12. #4392
    Feb 2004
    1311
    Totally awesome Hoss. That bottle attachment adapter is too cool.
    Cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
  13. #4393
    Quote Originally Posted by mhackney View Post
    Cheers,
    Michael
    Thanks a lot!
    It's been 9 days on this project so I better get back to regular programming.
    Hoss
  14. #4394
    Jul 2008
    340
    What!? I thought innovative creative cool projects was "regular" programming. You do more!?
    Sent from my Xoom using Tapatalk HD
    CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
  15. #4395
    Nov 2009
    4415
    Quote Originally Posted by Analias View Post
    He has still got a laser around there we haven't seen. Stay tuned. Maybe trimming or fusing the edges of a print? 4 or 5 axis, trunions and a laser? My imagination is already at a dead end. Wear laser proof glasses.
    A lazy man does it twice.
  16. #4396
    Mar 2004
    1806
    Hoss,
    It is obvious the O rings do a great job. Have you tried to add them to the "original" cups also??? And what size rings did you use?
    Thanks in advance.
    Art
    AKA Country Bubba (Older Than Dirt)
  17. #4397
    Thanks guys.
    Bubba here's the parts list and yes I used these o-rings on the real cups too.
    Powder Coat Cups Parts List
    (Circlip for Lock Knob)
    Side-Mount External Retaining Ring (E-Style), Black-Finish Steel, for 5/16" Shaft Diameter
    McMaster.com #97431A310
    (O-rings for Cup Cap)
    Soft Buna-N O-Ring, AS568A Dash Number 013, McMaster.com #2418T119
    Soft Buna-N O-Ring, AS568A Dash Number 032, McMaster.com #2418T134
    (Glues for part assembly and sealing)
    Weld-on #16 Cement for Acrylics, 1-1/2 oz Tube, McMaster.com #7515A11
    Weld-on #3 Cement for Acrylics, 1 Pint Can, McMaster.com #7528A13
    (Soda Pop Cap for XC Cup) from many 2 liter,1 liter, 16,20,24 oz pop bottles
    Hoss
  18. #4398
    Mar 2004
    1806
    Hoss,
    Many thanks as always!
    I guess now I will have to get/make a 3d printer to keep up with you:})
    Art
  19. #4399
    You should, everyone should have at least one in their shop.
    I remodeled the Super Capacity cup for more clearance and strength.
    Someone suggested I try to get Sears to buy it, too bad they don't sell these powder coaters anymore.
    Hoss
    Attached Thumbnails Attached Thumbnails powder coat cup body SC2 001.jpg   powder coat cup body SC2 003.jpg
  20. #4400
    A fellow on youtube (builtrodewreckedit) made a suggestion an hour ago to make a funnel to screw onto the powder bottle so you can refill the little cups without a spoon as I did in the video.
    Here's what I came up with, you can still keep the contents dry with a pop bottle cap.
    Hoss
    Attached Thumbnails Attached Thumbnails 1lb funnel cap 001.jpg   1lb funnel cap 002.jpg   1lb funnel cap 003.jpg
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
