588,178 active members*
4,316 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 24 of 41 14222324252634
Results 461 to 480 of 808
  1. #461
    15362
    Re: Huanyang Chinese VFD settings and manual here!
    Quote Originally Posted by Hyperryd View Post
    I have 24v supplied to the 12-24v terminals. Should I lower to 12v? I had this table built from a guy who didn’t send any diagrams. Not happy about that but I am learning fast. I appreciate your help.
    This is is the inside of the controller.
    24v is ok, but if you see / feel it getting to hot, you will have to go with 12v, some of these Breakout Boards can't take the 24v even though they say it can
    Mactec54
  2. #462
    Feb 2018
    Ok so in thr picture white=top spindle switch terminal. Black=bottom spindle switch terminal. Red =1-10 volt+ top terminal. Green =bottom ground terminal.
    The spindle cable is not shielded. I will order that, but can it run for now?
    i set all of the parameters to match and I have the jumper on v1.
    I try to engage the spindle from Mach3 I get nothing. If I press run on the front of the VFD it spools up and runs until I hit stop.
    What am I missing to control from Mach3? It’s probably simple but not to me today.
  3. #463
    Jan 2007
    626
    You have to change the parameter that tells the VFD where it gets its start/stop commands from.
    At the moment it is using the front start/stop buttons. You have to change it to a remote contact.
    I don't own that VFD so can't tell you which parameter it is.It should be straight forward.
  4. #464
    15362
    These are the only needs for the VFD side, the rest of the settings are in Mach 3, if the noise from not using shielded cable is to high then it will kill any Terminal signals
    Start with getting the Relay working you will hear that turn on / off
    Then check that you have a voltage from the 0-10v in MDI type M3 S12000 you should have 5v at the Breakout Board
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    The Cable you need to get is CF6-15-04 IGUS
    Mactec54
  5. #465
    Feb 2018
    For some reason I kept putting zero in the PD001 and 2. Now it isn't working from the front panel of the VFD, which I believe is good. The next question is does anybody know where I can get the correct Mach3 settings for this board and VFD?
  6. #466
    Dec 2014
    46
    No you cannot run 24v motor with that VFD you need a 24V power supply
  7. #467
    15362
    Quote Originally Posted by lt00273 View Post
    He is running a 220v Spindle Motor
    Mactec54
  8. #468
    Feb 2018
    So let me ask this another way. Do any of my config settings look wrong for this bob and this spindle? I’m getting no click at the relay on the bob. I’m thinking it is a config issue.
  9. #469
    15362
    Hyperryd
    Your Pulley settings should be 6000 and 24000 and may have to change the ratio to get the speed to match
    What do you have in motor tuning for Spindle this has to have at least 1 step Velocity and acceleration can be any number
    In the Diagnostics screen
    Does the output 1 turn on when you type in M3S12000 this needs to turn on your Relay and a M5 should turn it off
    Are you using PWM 0-10v or Step /Dir to control the Spindle Speed
    Mactec54
  10. #470
    May 2009
    1347
    Try to setup Mach3 as per attached screens
    Nicolas
  11. #471
    Apr 2018
    5
    For the On /Off you connect the FOR and DCM to the Breakout Board where it says Spindle Switch
    For the Speed control you Use VI and ACM to the Breakout Board Where it says Speed Control this is your 0-10v PWM
    You need to add a 12v Dc power supply to the Breakout Board where it says 12v-24v Power
    Your 240v Ac single phase input Power wiring is best connected to R and T terminals and Ground to the Ground Terminal
    You need to use Shielded Cable for the VFD to Spindle Connection, and need to make sure the 4th Pin is connected inside the spindle
    These Parameters need to be set, if you have not already set them
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (Motor Rated Voltage, If you have 120v spindle then set to 120v )
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=10 ( Adjust to suit)
    PD015 Deceleration=10 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD023=0
    PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )
    I guess pd073 and pd005 to 50 htz.
  12. #472
    15362
    Quote Originally Posted by blinkstrikebob View Post
    No you can not run your spindle at 50Hz, PD005=400 = 24,000 RPM, the minimum speed for these spindles is 6,000 RPM =100Hz
    Mactec54
  13. #473
    Feb 2018
    So I have control of the on/off and speed control from Mach 3. Problem is the speed control is backwards. Faster is slower. Is this a setting I can change?
  14. #474
    15362
    Would have to know what setting you have used in Mach3
    Also check the wiring to the VFD the VI to ACM is correct
    Mactec54
  15. #475
    Feb 2018
    Sorry for the double post. My tablet didn’t show the first one. I’ll check and post.
  16. #476
    Feb 2018
    So the 1-10v from the bob is going to VI and the ground next to it on the bob is going to the ACM.
    When I set the speed in Mach 3 to 6000 rpm the VFD shows 400. When I set the speed to 24000 the VFD shows 125ish.
    See attached Mach 3 screenshots.
    Another question, can the VFD show rpm or only hz?
  17. #477
    Feb 2018
  18. #478
    15362
    Hyperryd
    I don't see anything in your Mach3 Settings that would cause this problem
    See that the 12v Power supply Positive wire and Negative wire is connected to the correct Breakout Board Terminal
    Check the output from the Breakout Board, is Positive and this wire is going to VI and the Negative is going to ACM, is there any jumpers on your Breakout Board that need to be changed, photo of your Breakout Board
    You could check these Parameters also
    PD070=0
    PD072=400
    PD073=100
    PD074=0
    Mactec54
  19. #479
    Feb 2018
    I checked it’s input polarities and they were good. (24v)
    The output to VI ranged from .6-10v when I adjusted speeds in Mach 3 and those polarities were good too.
    Pd070 was 1, changed to 0.
    Pd072 was 400
    pd073 was 120, changed to 100
    pd074 was 0
    Still have reversed speeds. See pics of bob.
    Can I set the VFD to display RPM?
  20. #480
    15362
    Pd072 was 400
    pd074 was 0
    Depending on the VFD you have, on the keypad you can change the mode to show RPM
    You sure that the PWM 0-10v output from the Breakout Board, is positive output and not a Negative output
    Check that the Jumper for the VFD Terminal control is in the right position
    If the Jumper is correct, there may be a Parameter that is not correct some where, the only why to know if there is an incorrect set parameter somewhere is to do a ReSet and set only the Parameters I have given you
    Mactec54
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
