603,340 active members*
4,571 visitors online*
Page 27 of 75 17252627282937
Results 521 to 540 of 1507
Hybrid View
    Sep 2011
    1183
    Thanks Gerry..
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Feb 2010
    371
    Gerry,
    Love your screen set. I have something odd happening. If I start up Mach, then enter in amy G code command, then switch over to the probing screen, then switch back to the main screen again, mach crashes without error code; it just goes away. Have you ever seen this happen?
    35494
    It doesn't crash here, on XP with the latest development version (or any other version I've tried)
    What version of Mach3 and what OS are you using?
    Are you using the parallel port?
    I have one other user with a similar issue. His crashes when he clicks the probe wizard button, but it doesn't crash if he opens it from the Select Wizard window.
    He's using the latest development version, on Window7 x64 with an ESS.
    The Mach developer is looking into it.
    35494
    Vectric Post
    Here's a post I use with Aspire and V-Carve Pro with the 2010 Screenset.
    It eliminates the initial toolchange, and G43 length offsets.
    It also moves to the Park position at the end of the file.
    Attached Files Attached Files
    Sep 2011
    1183
    Gerry who is this file for?
    Lou
    35494
    You and anyone else that wants to use it.
    Sep 2011
    1183
    Gerry Thank you..
    Lou
    Dec 2007
    101
    Thank you for the modified post processor Ger. That will help tremendously since I have a habit of forgetting to remove that darn first M06.
    Sep 2011
    1183
    Gerry where do I place the post I downloaded?
    Lou
    35494
    Go to the Windows Start menu, and find V-Carve Pro, and there should be a User Data folder Link. In that folder, there's a Posts folder. Put it in there.
    Sep 2011
    1183
    Gerry thanks..
    Lou
    Feb 2009
    499
    Mach 4?
    Hi Gerry, I love and use your screen set daily.
    Was wondering: Since the CNC workshop was in your neck of the woods, did you go?
    If so, I heard that they talked about an impending (believe it when I see it) Mach 4. So,
    Do you have any ideas about how your screen set will fit into this new version? Is it too early to tell?
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
    Sep 2011
    1183
    There is a lot of talk about Mach4 on the Mach Yahoo board I think it is still being developed..
    Lou
    35494
    Quote Originally Posted by revwarguy View Post
    I would have, had I not been on the beach in San Diego on Friday.
    I don't believe that any Mach3 screenset's will work with Mach4 when it's released. They eventually may, but most likely only stock functions will work, as Mach4 is using a new scripting engine (Lua).
    Mach4 is a total re-write, and will not be a free upgrade.
    It should allow for much better screens, with many more functions. I'll definitely be looking into making a screen or two for it.
    Sep 2011
    1183
    What I have read there will be different versions or levels of Mach4 I am happy with Mach3 and the 2010 screen set..
    Lou
    35494
    If you want the auto calibrate function, it's not in there. I don't use it, and my theory is that valuable screen real estate shouldn't be wasted for a function you use only once, when setting up your machine.
    You can simply load the 1024.set screenset, calibrate, and then load the 2010 Screenset.
    Or just do the math and enter the steps/unit in motor tuning?
    I'm curious. Is this a fresh install of Mach3? I would expect most people getting my screen would already have a working copy of Mach3, which would normally mean the machine is already running, and the auto calibrate function shouldn't be needed anyway?
    Jan 2012
    29
    No problem. That was my backup plan anyway but nice to have it confirmed.
    Yes its both a new machine and a fresh mach3 install.
    May 2012
    Hi Gerry,
    On the "CNC for Woodworker" website, there is a red note about some problems with Mach3 version 3.043 ...
    And the only version I found is the 3.043 ... Sure, I can use the development release, but I'm not sure about that ...
    So, do you still have problems with that Mach3 release ??
    Thank you,
    Yves
    Sep 2011
    1183
    Quote Originally Posted by beluga282 View Post
    Hi Gerry,
    Thank you,
    Yves
    Here is a link to other Mach3 versions..
    ftp://machsupport.com/Mach/
    Lou
    35494
    Yes, you can use the Development version. The lockdown has not been updated in almost 2 years, and still contains the M6 bug.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
