Originally Posted by
flyfish
I have gone back and worked thru your videos to make sure I'm doing everything correctly.
I am using your version 5.0.6 on my pc with Win 10 64 bit.
My machine is a SainSmart Genmitsu 3018-PROVer with a PGFUN CNC 3D Touch Probe.
I use a small piece of construction foam as a test part so that I don't break anything (attached picture).
One thing I am having trouble with is in your video "Aligning the work piece", I don't get the white outline you show. The toggle switch in the upper right doesn't seem to show it. So I am unable to select it as you show in the video.
I am able to scan a surface as you can see in the attached picture. However the blue points and the surface are not at the probe location. I have set the workspace location after going through all the probing settings (work piece zero and aligning).
I'm beginning to think that the machine default settings which are all the way to the right side of the table are ignoring the workspace settings.
I have tried everything I can think of to correct this to no avail.
I really like the program, I just need help with it.
