Screenie..
Screenie..
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Screenie
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
One more..
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Rekd any chance to get hold of your last version of this program?
Yeah, PM me monday and I'll get it.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Will do, thanks!
moved to new thread
Have a look at this.Originally Posted by phillipmc
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
moved to new thread
moved to new thread
Your PM folder is full, cant send to you.Originally Posted by Rekd
Updated version of SComm.
After you install, copy the SComm.EXE file to the install directory and over-write the existing one.
If you have ?'s or !'s lemme know.
http://members.cox.net/fuknrekd/Scomm Setup.zip
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
I was going to try your program but the last scomm setup.zip seems to be empty.?
Oops. Will upload a new one. That's weird.Originally Posted by meconer
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Ok. All better.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
I tried to download it again from the link above and it seemed to be empty again. But then I right clicked it and chose to "Save link as" instead and this time it worked. Probably would have yesterday to. My bad. Sorry to have caused you extra work. I will try your software next week. We usually use cimco edit (mastercam version) to send/receive programs to one of our mills. But sometimes I need the hardware lock elsewere and then it's good to have an alternative.
I used to use an editor I programmed myself in delphi years ago but after we got a new computer with xp the communication no longer works. I had big plans for this editor but the time to develop it never seems to come along. And now of course I have the cimco editor.
Hi again
I tried your prog at work today. I had problems with the recieve module. When I sent from our Chiron mill with Fanuc 21-m I got everything on one long line. I didn't see any settings regarding this in your program. Are you aware of anything I can do to get around it? And by the way, thanks for your good work and for letting other people benefit from it.
regards Mats
The recieve portion has it's own settings, but does not include the option to add CR/LFs. There should be a setting on your machine's controller to send them, and SComm will pick them up.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Rekd, How do you use polling with another program. Can you send a file using arguments ? Ex. scomm.exe,test.nc
Could you explain a little of how polling is used?
no problem!
Polling and arguments go hand in hand. Yes, you can send a file name to SComm and have that file loaded for the send operation. (I haven't set it up to change any settings yet, except to optionally bring up a port select window)Originally Posted by speedracer
With polling, if SComm is already running, the 'new' instance will send the file name to the registry, then exit.Code:SComm.exe c:\pathname\filename.ext
The 'original' instance will read the registry every 5 seconds to see if that 'key' has been modified. The value for the key is the file name. If there is a value detected, it sends that to the console and loads the port select option, if enabled. If port select is not enabled, it will just start sending.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
