588,014 active members*
6,704 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
Page 3 of 3 123
Results 41 to 59 of 59
  1. #41
    Apr 2006
    3498
    This is the 2nd Part i machined out of SS316, 30mm thick plate.
    Used Facing, Profiling, engraving and drilling operation.
    I am getting gouging at smaller radius wall of the part.
    Thank You Zafar for converting this into CNC . I can easily get 0.5mm deep cut on SS316 but my spindle motor is week for more than 0.5mm cut.
    Here is the Video:
    [ame="http://www.youtube.com/watch?v=wUttTrtwpvc&feature=g-upl&context=G2935e6bAUAAAAAAAAAA"]http://www.youtube.com/watch?v=wUttTrtwpvc&feature=g-upl&context=G2935e6bAUAAAAAAAAAA[/ame]
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  2. #42
    Apr 2006
    3498
    Some Pictures of the finished product:
  3. #43
    Feb 2007
    191
    Hi Khalid
    Nice work!! Congratullations..
    By the way.
    I post you a PM.
    Could you help me?
    Regards
    Rene
  4. #44
    Dec 2005
    112
    Wow, Khalid. You are already making parts on this mill. I thought you'll give it some break-in time. Did you do the engraving with the tool I made?
    For the spindle stalling problem, I guess you are using too low frequency for the motor. Using SS tools perhaps. I'd suggest using carbide tools and high rpm's above 1500 or so. You'll need good collets and holders too. I'll get some for you on my next visit.
    Zafar
    Quote Originally Posted by Khalid View Post
    Here is the Video:
    Milling SS316.flv - YouTube
  5. #45
    Apr 2006
    3498
    Quote Originally Posted by zafarsalam View Post
    Zafar
    Dear Zafar,
    Thanks for the suggestion about increasing RPM of Spindle Motor and use of Carbide tool. I did that engraving with your machined tool...I have got slight depth in consequent engraving and that might be due to spindle warming.. So we made a rule of thumb as to start Spindle and wait for 5 minutes before pressing the Cycle Start..
    I shall wait for the Collets and Holders and i hope you shall send us as early as possible as our TA of Plant begins from coming Monday so we need them most..
    I am getting some tool gouging marks at smaller radius walls.. Whereas The bigger radius seems smooth at the entire place, only a small gouging mark at tool entry location at bigger radius..I have to change entry /exit parameters outside the part to get smooth finish..
    Milling SS316 with DIY CNC.flv - YouTube
  6. #46
    Dec 2005
    430
    To get rid of that gouge mark, try to use a lead-in, lead-out if you can. It creates a small radius at the end of the tool path. Lead-outs at the bottom of a part like that will need clearance, otherwise you'll crash the tool into the left over stock. You could also use a ramp, instead of many depth-of-cut passes.
    And I like that spindle light. Is it LED? I'm getting 2 of these: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices from China, and I hope they'll produce lots of light.
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  7. #47
    Dec 2005
    112
    Dear Zafar,
    Khalid,
    I would suggest using lead-in and lead-out to remove the gouge marks and also use rough and finish passes. I buy my tool holders and collets from KTD (PVT.) LIMITED you can contact them on the phone numbers at their website and inquire about the availability of ER40 collet holders and collets with MT5 shank. The ones I have are with BT40 shank. If you have adopters for BT40 then you can get these too. I'll be out of town this week. You can ask Mr. Nooruddin to buy the tool collets/holders for you and send them to you.
    The engraving tool cutting again on the same depth of cut is due to your tool runout. It is not producing a smooth cut so it appears that it is cutting again with subsequent cuts. I had noticed it when I tested your machine with that tool. A good collet holder will take care of that.
    Zafar
  8. #48
    Apr 2006
    3498
    Quote Originally Posted by skmetal7 View Post
    I used 3D Ramping for each passes for that part... but it is a good idea to use tangential lead-in and lead-out in my next oncoming part.....
    Yes this is 10Watt LED Light (220VAC) i purchased for 14 US Dollars in local store... The light is too bright and awesome...
  9. #49
    Dec 2005
    112
    I just watched the video. You are using climb milling. That will pull in the tool where the axes reverse direction (at the quadrants of circle) because of the backlash. Use conventional milling and also rough and finish passes. A 0.5 to 1 mm finish pass will produce good results. The feedrate is 20 ipm or mm/min?
    Zafar
  10. #50
    Apr 2006
    3498
    Zafar
    I am using Mixed Milling technique and i think your analyses about tool gouging is right. However i shall mill the same part later using Lead-in and Lead-out and will check the results... The feed rate was variable.. For 0.5mm cut we have feedrate 150mm/min whereas ramping till total tool engagement it was 27mm/min...
    The engraving toolpath was single pass... I think the tool/spindle warm-up made a slight 0.05mm difference in engraving depth....
    For the tools i shall contact Mr.Noorudin,... He is really an expert in CNC Control system
  11. #51
    Apr 2006
    3498
    Quote Originally Posted by cncmakers001 View Post
    Nice work.
    Thank You.
  12. #52
    Apr 2006
    3498
    Part was removed, deburred and polished.
  13. #53
    Apr 2007
    1955
    Khalid, that is very nice work.
    You are somewhere on project 10 or something, and I am just starting project 2. (project 1 turned out to be mostly learning)
    Take care,
    Harry
  14. #54
    Apr 2009
    5516
    Nice work!
  15. #55
    Feb 2010
    3447
    Here is the 90% completed machine
    This is an awesome build!
  16. #56
    Apr 2006
    3498
    Thank you, here is the drilling video. 19.30mm drill on 60mm CS plate.
    Today experimented the grooving. This is mock-up of tube sheet for weld qualification.
    [ame=http://www.youtube.com/watch?v=smgMUNo7J4w&feature=g-upl]Drilling of Holes 60mm deep CS plate.AVI - YouTube[/ame]
  17. #57
    Apr 2007
    1955
    That is very nice work to drill something deep. My brother and I did a 19mm diameter x nearly 80mm deep hole set once (but only once). Getting the chips out was challenging, and made me really realize why horizontal boring was invented.
    If you ever get a chance to use a 7000 series Al, or one of the alloys with lead (Pb) you will never want to use 6000 series Al alloys again.
    Unlike those dangerious, long, strings of Al that came from drilling in that video, they make very nice, short, broken chips.
    Thanks for sharing.
    Harry
  18. #58
    Apr 2006
    3498
    Hi Harry,
    Thanks but this is carbon steel not Aluminum.
  19. #59
    Apr 2006
    3498
    Material : Carbon Steel
    Thickness: 50mm
    Cutter: 16mm Carbide
    Depth of Cut/Pass: 1mm
    milling Type: Climb
    Spindle Speed: 1002 RPM
    Blended Feed: 450 mm/minute
    With Lead in and Lead out.
    [ame=http://www.youtube.com/watch?v=g80vaQ5jd4Q&feature=g-upl]Machining of Bracket.flv - YouTube[/ame]
Page 3 of 3 123
  1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  2. Anyone in the East Tennessee area doing a mill drill retrofit.....
    By pete from TN in forum Benchtop Machines
    Last Post: 05-04-2008, 02:00 PM
  3. Yoshida Radial Arm Drill Press
    By jnsane84 in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2008, 08:31 PM
  4. Where to begin? Retrofit a Stepper Control to a Mill-Drill?
    Last Post: 05-04-2004, 11:44 PM
  5. CNC retrofit for Mill/drill?
    By Jkier in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2003, 12:42 AM
