Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
At this time I don't.
Phil,
Thank you for the single axis board.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Any chance someone might have a four axis board?
Jeff...
We finished :violin:
Galvanic isolation
Double layer
:wee::wee::wee::banana::banana::banana:
Elforum,
Will you share the eagle files for your board?
Thank You
JoeyB
A doughnut a day keeps the doctor away.
Here eagle schematics and board
Elforum,
Why didn't you install the opto isolators on your board?
What opto where you going to use?
Thank You
Jeff...
TLP621-2 and TLP621
not I had
Phil, I have a few questions. I have a breakout board that needs a 5V power-supply. Can I use it to power the boards too and skip the whole 7805 part or is it an important part of the operating circuit?
Where do I get the 'enable' from? Is it from the breakout board? If yes, where on a board would it be?
How de heck do I solder a device to both sides of the board if it sits on the pad and covers it?![]()
Just increased my count by one.
Where on the board is connected R11 and R12? On board in eage I dont see many connection at left and right side of board.
Edit:
More connections are lost. I download second time your board and someting is wrong i think.
GND
Push in Eagle RATSNEST, NO LOST CONECTIONS
TigerPilot did not understand what you mean
1 yes Switches also posible replace pover resistors, please read datashet TB6560 page 10, torque setting. Power resistors is 2x0,33R metal oxide in parallel
2 Yes
3 http://www.cnczone.com/forums/showpo...2&postcount=52
I got out and sell
http://www.hi-end.ro/driver-cnc-pent...as-p-2379.html
