588,300 active members*
4,845 visitors online*
Page 31 of 32 2129303132
Results 601 to 620 of 638
  1. #601
    Re: XYZ Probe modification
    That macro is from my 2010 Screenset, and will only work with the 2010 Screenset.
    All the GetDRO calls in the 1800 range are DRO's in the 2010 Probing wizard screen.
  2. #602
    Mar 2015
    6
    Wow! Can I get a demo or temporary version of your screen see if it works? of course I'd be happy to buy it if it does
  3. #603
    Feb 2016
    4
    Hi, I have just joined the site and have downloaded your programme. it's all gone in to my Mach3 but I keep getting the old screen with the spindle speed in the bottom right corner. I have tried to down load the new screen set but am unable to get it to change to the new screen with the probe window in the corner. can you help?
    Bob
  4. #604
    May 2014
    29
    Quote Originally Posted by minimax0 View Post
    Bob
    Hello! You, can not install BlueProbeVer3?
  5. #605
    Feb 2016
    4
    Hi, Sorry are you saying that it will not work?
    Bob
  6. #606
    May 2014
    29
    I ask you. You want it?Click image for larger version.
  7. #607
    May 2014
    29
    if this is what you need. write to me on Skype ( nikolaipapkov )
  8. #608
    Sep 2005
    371
    Did you try the "Load Screens" from the "View" drop down menu in Mach3 and select the new set file?
  9. #609
    May 2014
    29
    Yes
    write to me on Skype, I'll try to help.
    my skype, nikolaipapkov
  10. #610
    Feb 2016
    4
    Hi, Yes I went to the Vectric site and loaded the installer, that gave me the old interface I then downloaded the up dated screen and copied it over the old screen shot in Mach3. when I go to the view click Mac Blue Set I still get the old screen. as I say I have tried all ways of doing this with no success.
  11. #611
    Feb 2016
    4
    Hi, Sorry I don't Skype!!!
  12. #612
    May 2014
    29
    check the folder private messages
  13. #613
    Mar 2012
    192
    I've had a slight problem with the Z zero routine in these blue screens. I'm new to all this and just ran the routine from a fresh boot and 0 plate thickness. I recall a message about having 0 feed rate, but was kind of panicking at the moment and was hitting the estop. This was done with a digitizing "6 ball" type probe that I just made. The probe seems to work fine (I'll post another with a digitized image taken right after this crash - no repairs or re-calibration needed). I do not recall what my feedrate was set to, but it looks like the macro encodes 4ipm and will move 2 inches before stopping without feedback. It moved quick, like at rapid.
    Any idea what caused the crash?
  14. #614
    May 2014
    29
    On my machine, there were some problems, until I grounded all parts of the machine, and the replacement of wire shielded. After that, mah3 problems nebylo. Regarding your problem. It so happens that after the use of the cutter, remain on the tip, the processed material particles. This prevents contact of the probe and may not work. When reusing the cutter, be sure to clean the face.
  15. #615
    Mar 2012
    192
    I can check the probe contacts again. These are self contained in the probe body and I had not cut anything - so far I've just been testing the probe and it's a normally closed contact. However, the symptoms of full rapid Z and the message line, something like "cannot perform probe with zero feed rate" are unusual. It's like eggshells now. There must be this warning message coded somewhere in the software. Are these messages in plain text so I could search some files and try to get an idea of what might have happened? Thanks.
  16. #616
    May 2014
    29
    To view the macro, do the like in the picture.Click image for larger version.
  17. #617
    Mar 2012
    192
    Yes, I'm using the stock macro from the probe modification download file in the first post. Maybe I need to check it again to make sure I did the mod correctly. I think I recall that it would not zero the DRO, but it did seem to work very well. And the hole center worked just as well, although a mishap in the XY plane will break the probe for sure.
  18. #618
    May 2005
    11
    Quote Originally Posted by 1875 View Post
    I found a simpler Z zeroing vb script that works well.
    Yes you have to enter the height of the prob base plate in the code.
  19. #619
    Mar 2012
    192
    What would I enter for the probe base plate if there is no base plate, because I am using a direct sensing probe (ala 6-ball style)?
    Can you post the simpler Z-zeroing script? This is the one I am using:
    Code:
    Rem	VBScript To probe In the z axis
    If GetOemLed (825) <> 0 Then 		'Check to see if the probe is already grounded or faulty
    	Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
    Else
    	Code "G4 P1"			'Pause 1 seconds to give time to position probe plate
    	PlateOffset = GetUserDRO(1151)	'Get plate offset DRO
    	CurrentFeed = GetOemDRO(818) 	'Get the current feedrate to return to later
    	Code "F4"			'slow down feedrate to 4 ipm
    Rem	Probe in the z direction
    	ZNew = GetDro(2) - 2		'probe move to current z - 2 inches
    	Code "G31Z" &ZNew
    	While IsMoving()		'wait for probe move to finish
    	Wend
    	ZNew = GetVar(2002) 		'read the touch point
    	Code "G0 Z" &ZNew 		'move back to hit point incase there was overshoot
    	While IsMoving ()
    	Wend
    	If PlateOffset <> 0 Then
    		Call SetDro (2, PlateOffset)	'set the Z axis DRO to  plate thickness
    		Code "G4 P0.25" 		'Pause for Dro to update.
    		ZNew = PlateOffset + .25
    		Code "G0 Z" &ZNew 		'put the Z retract height you want here
    		Code "(Z axis is now zeroed)" 	'puts this message in the status bar
    	End If
    	Code "F" &CurrentFeed 		'Returns to prior feed rate
    End If
  20. #620
    0.0
  1. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  2. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  3. Need probe macro for M&H Infared Probe 25.41-HDR
    By nikolaiownz in forum Fanuc
    Last Post: 02-11-2012, 03:10 AM
  4. need help with modification
    By ironofeden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 06:21 PM
  5. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:46 PM
