Originally Posted by
on7tim7
Hi, You have done a beautiful job! This is something that I always wanted to have on my mill. I followed all your instructions and everything went great! Only I have a problem that probably you will know what its causing it. On the blue screen the "touch plate led" is not complete off as it should be till you close the circuit with the probe, it will turn on green. Mine is blinking all the time, and it turn solid green when the probe touches ground as it should but when I run any of the on screen test, let said "find the center" the machine is not responding at all. I have checked almost everything including the PC. The breakout board is working fine for the limits that are normally close switches and I have tried all the input pins. Do you have an idea of what should I check next? Thank you for your time and dedication.
