how to start the hobby cnc mill?
Metal Cutting Lathe
Knee Mill
Surface Grinder
Metal Cutting Bandsaw
Drill Press
Wood Machines only
Monarch 10ee precision lathe, Smart and Brown model M lathe, Bridgeport clone kneemill, 7x10 bandsaw, Emco PCturn120 cnc lathe, Tormach PCNC 1100, Sanford surface grinder, bench grinders, pc with solidworks, 2 cats and bunch of custom made bikes.
Dennis
CNC Shoptask Bridgemill
Grizzly 6X10 bandsaw
Bench drill press that was my Grandfathers
12X12 surface plate
6" Kurt mill vice
3" phase II mill vice
6" CNC rotary table
8" bench grinder
Bench top English Wheel
12" DeWalt sliding miter saw
Woodmaster (Shopsmith knock off) with 6" jointer, 6" belt sande, and band saw attachments
Foley Belsaw 12" wood planer
Foley Belsaw 1055 grinders
Lots of hand power tools
Full box of mechancis tools
Lots of rivet guns, cleco fasteners, air drills . . .
Air compressors
Oxy/Acet welding equipment
David
Bridgeport series II variable speed mill w/dro
6" Kurt vice
12" ROTARY table
8" spacer
14 X 40 geared head lathe from Wholesale Tool
Hobart 300 Cybertig tig welder
Miller 150 Mig
Brake / roll/ shear
36" DoAll 3 hp bandsaw
Pullmax P-5
30 ton Hydraulic press
1 1/2 ton press
Imperial Wheeling machine
2 Helve hammers
2 bead rollers
shrinker / stretcher (lancaster)
2 Bike lifts
2 post 9000 lb lift
JD2 Bender
truing stand
Sunnen hone
Souix Valve grinder w/seat grinder
13 punch presses
6 X 9 bandsaw
powermatic belt / disc sander
planishing hammer
my garage shop consists of:
Powermatic Millrite
Powermatic Surface grinder
Rusnok mill
Craftex 10x18 lathe
7x12 horizontal bandsaw
Vertical bandsaw
General belt sander
Miller econotig
12 inch Craftsman metal lathe. Built 1948. Great lathe.
Drill press
14 inchDayton Metal band saw
Harbor freight green machine Lathe Mill combo
Shopmaster ElDorado bridge mill. I have just converted to CNC
Just starting out with my collection:
160A Mig welder
Stick welder
8" Pedestal grinder
12" Cut-off saw
Various hand power tools
Some wood working power tools
Pedestal drill press
Selection of 1 & 2 m/t drills
Air compressor
Air tools
Toolbox full of spanners, screwdrivers, pliers, etc
Also plumbed in air lines and quick release couplings around the garage. Looking at a lathe next (hopefully).
It's impressive to see what some of you guys have as well - some home workshops here would put a lot of engineering shops to shame over here!!
Bridgeport Anilam 3axis mill
Rockwell 14x48 lathe
Miller Syncrowave Tig Welder
JD3 Tube bender
Hypertherm Plasma
Belt Sanders
Compressor
Planishing Hammer
EnglishWheel
Bead Roller
Various dollies and bucks
Two 6 foot toolboxes loaded with bits and peices
Spray booth ( homemade 2x4 and plastic)
Parts washer (small tube)
Sandblaster
Various vices and tables ( rotary, elevating... ect. )
ALL in a single car garage with a couple motorcycles
Its a mess and its addicting
I have the following:
Saw Stop table saw with Incra LS table saw fence
with a JessEm Mite R Excel and a Forest woodworker II blade
DeWalt thickness planner with Wixey digital display on portable stand
General jointer
Milwaulkee compound Miter saw with Laser Kerf
Craftsman circular saw with laser
Jet 14" band saw with Kreg Fence, Carter bearings and quick tension release
Delta Drill Press with Pinnacle table and accessories
DeWalt scroll saw on stand
DeWalt cordless drill
Porter Cable corded drill
Porter Cable portable ban saw
DeWalt plunge router
Porter Cable 7518
JessEm router lift
Porter Cable 891 with vac grip
Bosch Router
Homemade router table with Incra LS super 25" fence
More router bits then I can count (several different sets for specific tools)
DeWalt belt sander
Antique John Deere air compressor
Leigh dovetail jig
DeWalt Grinder
Several palm sanders
Craftsman Scroll Jig saw
Craftsman vise
Kreg Pocket Hole master system
Clamps to many to count
And much much much more. I have enough alignment tools to keep everything running smooth. Drill bits of every type including Brad Point, forstner, and speed bits. :cheers:
But I do not have a Lathe, Radial Arm Saw, or a CNC but I'm not dead yet!
He who has the most tools wins!
come you guys, listing your portable power tools and vises? pushing the envolope and guilding the lily
now some of you want to talk about your vices - that might be very interesting, but lets start a new thread
1 mini lathe, 1 13X40 lathe, 1 manual mill, 1 30 year old Taiwan drill press that has been used as a light mill at times, tube roller, english wheel, plannishing hammer, bead roller, gas & mig & tig welders. Many misc. tooling. 2 airplane projects & motorcycle projects.
Mill,lathe,surface grinder, band saw,drill press,table saw, panel saw, mig welder, stomp shear, box break, rotex punch,hydraulic press
Four DIY cnc routers, largest 2' x 4' smallest 10" x 12"
Powermatic table saw
6" jointer
14" bandsaw
planer
Jet drillpress
metal lathe
misc hand power tools
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
12" tablesaw
router table
drill press
metal bandsaw
hurco bmc 30 mill
grinder
8"x12" lathe
2 large compressors
unused-brand new 200 hp. eletric motor
20 hp. rotary phase convertor
It's a 52'x32' shop
3 Small drill presses/ set up for specific jobs, re: depth and diameter
1 Large drill press
1 hammond dual 5hp buffer/polisher
1 Parts washer jet cabinet
1 small parts washer
1 horizontal Bandsaw
1 Chop box
1 180 amp Tig / Lincoln
1 250 amp Mig / Snap on
2 tubing bender/ jd2 and another with screw drive and follower
2 Tubing Notchers
1 Rod Bender
1 36" shear, roll, and break
1 7.5hp 80 gallon compressor
1 13 x 40 lathe , manual for now
1 Bridgeport BTC-1 just fully retrofitted:rainfro:
1 Bridgeport Boss fully retrofitted 3 years ago
3 Tool boxes full of tools.
1 Jet 12 x 32 disc belt grinder
1 Snap on Plasma 50 Amp
Tons of woodworking tools/ won't break this down too long
5 x 10 cnc router in pieces was machinetoolcamp kit working router I built but needed some changes so I disassembled for modifying.
I know its a little much for a home shop but I tend to dive into my projects head first
24 x 52 Backyard Barn (Started as 16 x 20 and kept(keeps) growing)
My little machine shop is in a spare bedroom in my home. I have no useful basement...
In there I have a 7x10 mini lathe, Taig 2017ER milling machine, drill press, air compressor, small hydraulic press, mechanic's type roll around three level tool box and two sets of shelves.
It's a bit cramped...
Mike N
No good deed goes unpunished.
My workshop is also a spare room in my house and measures 4.2 metres - although I lose 1 metre for through access, by 2.4 metres.
In that I have a Sieg C6 lathe, an X2 mill. There's 2 metres of bench space and lots of drawers for tools. Lot of woodworking power tools in there as well
Not much room for expansion, and only 1 power point
Regards
Geoff
help me. please i want to by x y and z axis three ball screw preloaded. where i by?
My Home work shop dubs as a Business and Hobby Shop.
This is my Metal Work shop.
This is a Elox wire EDM
This is a Bridgeport Milling Center
These are a Landis Surface Grinder & #3 Moore Jig Grinder
There is a Grizzly Engine Lathe too.
We also have 2= Drill Press's, One small one large.
Metal Band saw
Arbor Press
And in my Wood Working shop
I have a CNC Router table 40" x 28"
I am constructing a 48" x 60" CNC Router Table
I am also Retrofitting a Shopsmith Mark 5V Into a CNC Lathe.
The Whole shop has a central Vacuum System from Grizzly.
On-top of all that tooling for the machines, holders, ect.
5 Mechanic tool boxes full of tooling and tools.
many types of hand power tools.
30' x 40' Clear Span Steel Building
You can buy American Ball-screws From McMasters.com
Or if you want good Ball-screws, Cheap Price Try this guy in China
I have Bought over $3000.00 worth of Ball-screws from him, but you will have to wait 3-4 weeks delivery time.
http://stores.ebay.com/linearmotionbearings?_rdc=1
