588,227 active members*
4,861 visitors online*
Page 4 of 4 234
Results 61 to 62 of 62
  1. #61
    Nov 2012
    104
    Re: Wireless adapters
    Yes, I was connected to my router but when I want to go to the Internet I have to connect to my cell phone hot spot, so I went online and posted, when I connected to the router again to check it was all working.
    Thanks man, I appreciate your time and help
    Carlos
  2. #62
    Nov 2014
    8
    I had the same problem, sometimes connecting without a problem and sometimes i had to disconnect from the router and reconnect.
    This is how i solved the issue.
    Delete the Z mapped drive through command line on pc
    net use /del Z:
    On controller pc run ADMIN NETWORK, disable dhcp under the wireless settings tab and set a static ip
    Follow the Tormach's instructions to map the drive on your pc but instead of \\TORMACHPCNC\gcode in the Map network drive window, enter \\192.168.1.110\gcode
    192.168.1.110 is just an example, you will add your own ip address that you have set as a static on the controller pc.
Page 4 of 4 234
  1. RFQ for threaded adapters
    By turbodime in forum Employment Opportunity
    Last Post: 06-28-2010, 02:53 PM
  2. USB to 25 pin adapters
    By csmoak25 in forum Controller & Computer Solutions
    Last Post: 03-12-2010, 03:43 AM
  3. laptop ac adapters
    By tc2468 in forum CNC Machine Related Electronics
    Last Post: 03-03-2010, 08:49 PM
  4. M12VC Adapters
    By ramasule in forum DIY CNC Router Table Machines
    Last Post: 01-20-2008, 05:55 PM
  5. USB to Parallel adapters?
    By Chris64 in forum Gecko Drives
    Last Post: 12-28-2007, 06:40 AM
