588,075 active members*
5,074 visitors online*
    Jul 2007
    40
    USB to 25 pin adapters
    Will the USB adapter to 25 pin work to run Mach 3 or will I need to have a 25 pin port put on my computer
    You must have a parallel port. If you don't have one then get a PCIE one for your computer. The usb protocol messes up the timing so the standard usb to parallel adapter won't work. There are some usb solutions but they do all of the processing on board and they are very expensive. Good luck.
  1. laptop ac adapters
    By tc2468 in forum CNC Machine Related Electronics
    Last Post: 03-03-2010, 08:49 PM
  2. .1" header adapters?
    By realsquash in forum CNC Machine Related Electronics
    Last Post: 07-10-2008, 01:05 PM
  3. 3 Shaft Adapters/Couplers
    By klick0 in forum Employment Opportunity
    Last Post: 04-18-2008, 05:37 AM
  4. M12VC Adapters
    By ramasule in forum DIY CNC Router Table Machines
    Last Post: 01-20-2008, 05:55 PM
  5. USB to Parallel adapters?
    By Chris64 in forum Gecko Drives
    Last Post: 12-28-2007, 06:40 AM
