Originally Posted by
TroyO
I just finished the epoxy-concrete fill. Some tips... assuming I don't have a big puddle of epoxy in the AM, anyway....
I used a 1-1/4" plumbing slip joint part to put through the big hole in the column. It seemed almost a purposeful fit... maybe a 32nd of an inch to spare. That filled in nicely with a bit of clay to seal it to the column from the inside. It also got a coat of grease.
I dipped the bolts in wheel bearing grease, then put them back in the column to fill in the holes. (4 mounting bolts and one tiny one for the ruler that is easy to miss.)
I sealed up the bottom of the column using aluminum sealing tape (Like for home ductwork.) Once I had a few layers over everything I went around and pounded the sealing edges with a rubber mallet. That squishes the tape flat and really gets a good seal.. it's a trick I've used before.
The mix was 8 Oz (4 Oz Resin, 4 Oz Hardner) of 2 hour Loctite epoxy from home depot and about twice as much concrete mix. (I really didn't care what the filler was for this use... sand, dry plaster... whatever.)
It made a thick slurry (Almost putty like), which was still flowable enough to fill in the gaps. I tapped the sides with a rubber mallet, and poked it with a stick a couple of time to hopefully shake loose any big bubbles.
The plan tomorrow is to untape it, knock out the slicked up plumbing tube and it should be ready. Maybe?
BTW, pleasant surprise... it came with a one piece drawbar. I had read somewhere that they came with a 3 piece drawbar. Guess that's since changed.
Unpleasant surprise.... I got the newer, cheaper and lighter style of the base with the open area under where the column is.
