588,268 active members*
10,747 visitors online*
Page 4 of 4 234
Results 61 to 65 of 65
  1. #61
    Jul 2004
    1424
    Re: Path Pilot 1.9.4 released
    Quote Originally Posted by Philbobb View Post
    I'm not a G-code expert, but everything I've ever seen has the tool change and height offset on different lines.
    Tormach's manual specifically calls out putting them all on the same line (section 7.7.3 in the 1100 manual). The post-processor that I use for HSM Works puts them all on one line.
    Quote Originally Posted by Tormach
    You are strongly advised to put the T~, the M06 and the G43 H~ on one line (block) of code. See G43
    for more details.
    Example: N191 M06 T3 G43 H3
    I suspect that Tormach "strongly advises" this as a best practice, just so you don't forget to do it, and so if you edit the code later on and change the tool number, that you won't forget to change which height offset is applied at the same time. PP show still react in the exact same way, even if the tool change and the height offset are separated by a few lines.
    To the OP: I seem to (vaguely) recall having an exact similar problem with PP earlier on. IIRC, shutting down and restarting didn't change anything, and think I ended up just doing a re-install of PP.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  2. #62
    Jun 2004
    6618
    That is how I like to see it too. Makes more sense when having to modify code by hand.
    F360 with my initial post did not but the tool number and offset on the same line. The offset was down a few lines. It still works with Mach 3 on the Novakon. Just looks different.
    (DELTA 3RD OP BACK F360 HOME FIRST)
    (BOTTOM LEFT ZERO)
    (T3 D=0.5 CR=0. - ZMIN=-0.6948 - FLAT END MILL)
    (T22 D=0.375 CR=0.1875 - ZMIN=-0.8011 - BALL END MILL)
    G90 G94 G91.1 G40 G49 G17
    G20
    G28 G91 Z0.
    G90
    (FACE2)
    M5
    M9
    T3 M6
    S4500 M3
    G54
    M8
    G0 X3.525 Y0.0548
    G43 Z0.6 H3
    Z0.2
    G1 Z0.0375 F30.
    G18 G3 X3.475 Z-0.0125 R0.05
    G1 X3.2
    X0.
    Lee
  3. #63
    Sep 2015
    33
    I've been using it today, and I'm going back to 1.9.2
    It's messing with my tool offsets. I didn't notice at first, but when I'm parting off for some reason it goes off by a tenth. After the parting operation my parting tool is not where it's supposed to be at all. I actually checked exactly where I wanted to part, and where the code was running it to on 3 separate parts, and after it started the g code, it just got all wonky.
    I don't know if anyone else is having this issue, but I'm just going back to 1.9.2 for now.
  4. #64
    Feb 2007
    1538
    Thanks - please tell Tormach. I will stay with 1.9.2 for now also.
    Keen
  5. #65
    Mar 2013
    344
    Carlos,
    If a particular tool has already been loaded PP won't ask to load it again, rather it will go right into program execution.
Page 4 of 4 234
  1. Networking Path Pilot
    By RA-Bowtie in forum Tormach PathPilot™
    Last Post: 12-29-2015, 05:39 PM
  2. Path Pilot - wish list
    Last Post: 07-13-2015, 12:12 AM
  3. Path Pilot Sub Routine
    By csm-Guy in forum Tormach PathPilot™
    Last Post: 04-08-2015, 05:23 PM
  4. Path Pilot - Rasberry Pi 2 b
    By tosatool1 in forum Tormach PathPilot™
    Last Post: 03-19-2015, 08:07 PM
  5. Welcome to the Path Pilot forum!
    By kstrauss in forum Tormach PathPilot™
    Last Post: 03-13-2015, 01:41 AM
