The previous re-design had a sealed ball race so lube was built in, whereas the roller bearing design calls for housing seals top and bottom to keep the grease in, dirt out.
It has been pointed out that there is some side deflectiion in ball races....practically non existant for all intents and purposes, and definately not measureable to any degree worth worrying about, and the roller bearings, being non taper, will also have this "problem" but not a problem as I see it for practical uses.
As the quill has a thin wall at the top, I will make a screwed retainer with a seal to retain the bearing outer race against a lower shoulder, and a screwed collar on the spindle to retain the inner race against a spacer on the spindle that retains the two angular contact bearings at the bottom.
The 3 phase motor interest came about when I bought a small (3/4 HP) VFD on Ebay for $250, and the fact that 3 phase motors are practically given away and can be speed controlled, which single phase can't, was a deciding factor.....the housing package is also a lot smaller for 3 phase.
