588,221 active members*
4,413 visitors online*
Page 7 of 7 567
Results 121 to 122 of 122
  1. #121
    15362
    handlewanker
    The paint on the mill is a 2 part epoxy I sprayed it on, it is not powdercoat, That mill has worked hard everyday for 10 years now, & still looks like that, It has a 30 taper
    As for the Needle Roller Bearings most have a Hardened sleeve that you can get for them
    they are very cool
    I built a grinder to grind the taper in the spindles
    Mactec54
  2. #122
    May 2005
    3920
    Whatever it is it looks really nice.
    handlewanker
    I was at the Cabin Fever auction today, there was an old Hardigne horizontal mill that looked like it just came off the show room floor. Well at least the paint does. I suspect youR mill will hold up as well.
    they are very cool
    That is cool, does this machine have an an automatic draw bar? There is obviously an extension on head.
    As to R8 spindles there are several vendors at Cabin Fever with old Bridgeport heads and spindles, I'm thinking hard about the wisdom in buying such for a rebuild. This would be for a future router type machine build. Frankly the heads I've seen so far are not "whole" if you know what I mean.
Page 7 of 7 567
  1. DIY ATC Spindle design
    By davidmb in forum DIY CNC Router Table Machines
    Last Post: 04-21-2020, 12:53 PM
  2. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  3. 100000 rpm spindle home made
    By goldi80 in forum Hobby Discussion
    Last Post: 10-14-2011, 03:43 AM
  4. My home made cnc - Need a good spindle?
    By Rajpage in forum DIY CNC Router Table Machines
    Last Post: 11-02-2010, 09:03 AM
  5. My Design for a home made Pendant
    By Steve-Tee in forum CNC Machine Related Electronics
    Last Post: 05-18-2009, 12:33 PM
