587,174 active members*
4,250 visitors online*
Page 72 of 76 22627071727374
Results 1,421 to 1,440 of 1506
  1. #1421
    Oct 2007
    446
    Re: Mach3 2010 Screen set
    yes i've modified my first probe feed in all of the macros....it works when i do a simple autozero...but when I use the autozero with toolchange its not going on the slower speed i specified by the first probe feed....
    Is there something else I need to modify for it to work with autozero with toolchange?? Different Macros I need to modify??
  2. #1422
    Did you modify all three macros?
  3. #1423
    Oct 2007
    446
    yes modified all three...that should work for the autozero with toolchange too then?
    I'll have to test again...but it sure did seem faster than then 6ipm i set...
  4. #1424
    Yes, M6end handles the auto zero after the tool change.
  5. #1425
    Jul 2011
    5
    Hi Gerry,
    I Purchased your 2010 screenset back in 2013 but never received any updates.
    If there is any can you please send them to me?
    Also have a problem now. I Had to go overseas for about 2 years now i'm back and started my CNC to see if everything is still working but no movement from the motors.
    Looking at the DROs I get nothing. What could be wrong? The machine was working perfect before.
    Gus
  6. #1426
    About a million different things.
    If the DRO's aren't working, make sure that mach3 is not in Reset, and that the motors are configured properly.
  7. #1427
    Jul 2011
    5
    Gerry,
    Thanks for the reply! I got that solved. it was just the button (enable jog)
    My other problem now is the soft limits only on the z axis. I keep getting an error every time I do a tool zero.
    I have about 4 inches of travel and a home switch at the z+ Today I was doing some test cuts creating some pockets
    and about five minutes into it the Zaxis will just plunge about an inch down it almost look like it was the ballscrew coupling
    But that's not the case. any pointers you can give me on that is appreciated !!
  8. #1428
    What is the error you are getting?
    The second issue sounds like your Z axis is stalling, or losing steps.
  9. #1429
    Jul 2018
    11
    Thank you all for your help everything is working fine.
    I have a friend that will only use window set 1024, is there any way he can do a tool change similar to 2010??
  10. #1430
    You'd need to either edit the 1024 screen to add the DRO's that the 2010M6 macro uses.
    Or, edit the M6 macro to include all the values that it normally gets from the DRO's. You'd need the M881 macro as well. And a button to call it.
  11. #1431
    Jul 2018
    11
    many thanks for your help.
    Mike
  12. #1432
    Jul 2017
    42
    I have the 2010 screenset and it is working great. Love all the features especially the tool change!!
    I am considering getting one of the drewtronics probes ( normally closed ) and a tool setter ( normally closed ).
    I can not wrap my head around what the process would be to use the probe for setting Z with the tool.
    Right now I start the program with the first tool in the spindle and it sets Z with the tool against the touch block ( normally open ), sets it again with the remote tool plate, and then starts cutting with the first tool. But I can't use the touch block for the first tool if I change the Mach3 setting to support normally closed.
    The one thing I could think of would be to have the probe in the spindle, start the program, let it probe Z against the work surface, go to the remote tool setter, probe Z, then have the program do a tool change to the first tool and it will then set Z for the tool off the tool setter, and then start cutting.
    I'm not sure the probes would be worth the effort then at least until I could get a real tool changing spindle.
    Any other ideas or suggestions?
    Thanks!!
  13. #1433
    Jul 2014
    16
    Hi Gerry, been using your screenset since I started. Lately the screen will not open to cover the entire screen, no trouble really just irritating. Can you help? I am sure it should be a simple fix I am just missing.
  14. #1434
    Jun 2010
    4256
    it's Windows. Just grab the bottom right hand corner and drag it out. Then save settings.
    Cheers
    Roger
  15. #1435
    You don't have ti save any settings.
    Just drag the window to fit, and close and restart Mach3.
  16. #1436
    Jul 2014
    16
    I drag the bottom right corner to the screen size I prefer every time. Yet it reverts back to that size once I restart mach3.
  17. #1437
    Auto Screen Enlarge is off?
    The only thing I can think of would be a bad .xml. Try replacing it with a backup.
    Mine always stays the size that i drag it to, and I've never heard of this from anyone else.
  18. #1438
    Jul 2014
    16
    Sorry for being a noob, but how do I do that?
  19. #1439
    Apr 2008
    127
    I have been using 2010 screenset for couple days with no problem, all tool change macros working.
    Today i have moved my fixed touch plate more to the edge of the cnc and now tool change macro behave strange.
    First touchplate its ok but when moving to fixed touch plate before it reaches machine stops. It is like sudden stop in XY and start to probing z axis. (before reaching fixed plate position)
    Anyone have similar problem ?
  20. #1440
    Are you using a chinese motion controller?
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
