603,802 active members*
4,892 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 89 of 91 39798788899091
Results 1,761 to 1,780 of 1805
  1. #1761
    Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    The Vietnam traveling wall will be in town soon, so I've been working on a nice set for my friends booth!
    The USMC & USN are done, the USCG & USAF are on the pain bench!
    The ARMY had a crack in it, so I've had to cut another one!
  2. #1762
    Finished painting another one!
  3. #1763
    All done!
    It took me a while to finish them, but its was worth the effort!
    Hope you all like them!
    Widgit
    And yes, the New Space Force is next, but the Seal & Logos have not been officially released
  4. #1764
    Jul 2018
    6841
    Hi Widget - What paint do you use thats so bright? Peter
  5. #1765
    Hello Peter!
    Actually, all I use is standard Matte finish Acrylic paints!
    All so, none of the last 5 plaques were clear coated yet!
  6. #1766
    Jul 2018
    6841
    Hi WM - Are they art type acrylic or housepaint? Peter
  7. #1767
    All Artist paints! I prefer the matte paints, as it's easier to add additional coats for better colors on the absorbent wood!
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  8. #1768
    I realize it's been an incredibly long time since I've uploaded anything from the machine shop, so here is a project I've been working on for several months now!
    As Big-Red is now running better, I've noticed the water cooled spindle is running too hot! After investigating the cooling system, I realized the water lines were circulating hot water as the machine ran for hours!
    My solution is to add a little radiator with a 150-CFM fan! In order to do this I'll need to add an air filter, to keep the fine dust from clogging the radiator's fins !
    I had a mounting bracket made out of welded aluminum, which will support both the radiator and the fan! But attaching the air filter required a little more detailing!
  9. #1769
    After mounting a 1" thick aluminum plate in the lathe chuck, I made a face cut and drilled a 2" dia. through hole. Next I expanded the bore to match the filter's bore!
    The I used a 45 deg. bit to make a nesting area that matches the angled protrusion on the ends of the filter! Then I turned the OD to match the filter's OD.
    Next, I needed to remove the Turret from the lathe, and put the single tool holder back on!
    This enabled me to flip the part, face the opposite side, and put a deeper 45 deg angle into the bore. this will improve the airflow from the fan's larger diameter to the filter's smaller diameter!
  10. #1770
    Now it's time to switch chucks, so I can hold the part in soft-jaws. Then I placed a spider under the three jaws, and bored out a nest for the part to clamp into!
    Because the next cut requires a long radius cutter, I free-hand made one on the pedestal grinder using a 1/2 x 1/2 HSS tool bit!
    With the tool clamped in position, I carefully made a series of cuts in the edge of the part. This created two flanges, one fits up against the filter. The other will be machined square, to match the fan housing, and have holes for the attaching screws!
    It's been a long time for me, and standing in the shop is still a bit painful! But I did manage to get the rotary table setup on the mill, and made a fixture plate to securely attach the part in the center of the table! This will allow me to mill the fan side flange square, and drill the mounting holes!
    But not today!
  11. #1771
    May 2007
    102
    Nice to see shop pictures once more .
    A tip I got from a retired painter :
    To stop wood from absorbing the paint and needing multiple coats , apply one thin coat of latex or emulsion paint first
    This will seal the surface and fill minor imperfections .
    Then paint as you normally would , spray or brush .
    Pat .
  12. #1772
    More progress!
    Today I milled the fan side flange square, and drilled the four mounting holes.
    Then I put the vise back on the mill, so I could drill & ream a 1/2" diam. hole across the center, 45 deg. from the four mounting holes.
    This allowed me to place an aluminum pin across the bore. After a quick trip to the welder, I had the ends of the pin welded in place.
    As soon as it returned to my shop, I placed the part back in the lathe and re-surfaced the edge radius.
  13. #1773
    The pin that crosses the bore will allow me to attach a long pin down the center of the filter, which will allow an end cover plate for the filter.
    That's a job for tomorrow!
  14. #1774
    Today I drilled & tapped a hole in the cross-bar, then I made a small spot-face the same diameter as the long shaft.
    Then I drilled & tapped the end of the long shaft, put a screw tightly into the bottom of the threaded hole, then cut the head off the screw.
    Next I screwed the parts together, and used the Height Gage transfer a mark onto the long shaft. Then I cut off the excess, drilled & tapped the end.
    With all that done, I drilled a small hole in a piece of aluminum plate, bandsawed the corners off and turned the OD on the lathe
    With a little radius tool, I made the top cover plate look nice!
  15. #1775
    Now It's off to assembly!
    Tomorrow I decide where on Big-Red it will be mounted!
  16. #1776
    Got them all finished!
  17. #1777
    Jul 2018
    6841
    Hi WidgitM - excellent metal and wood work. Keep it up. Peter
  18. #1778
    Mar 2004
    1806
    Widgit,
    You continue to amaze me with the work and service that you continue to do. Keep it up and stay safe.
    Art
    AKA Country Bubba (Older Than Dirt)
  19. #1779
    Thanks guys!
    You-all stay healthy !
    Widgit
  20. #1780
    WOW!
    It's been a long time sense I've posted on the Zone!
    Much has happened in my life, like another totaled Trike! So I've decided not to ride any more!
    My left foot has finally healed, after 4-years!
    Big RED has been running like a top, except for the PC! After trying to get V-Carve Pro to run on Win-10, I threw it in the trash and bought an old Win-XP system for $10 at a yard sale! Then I set the system Clock to 2001, turned off all the update junk, and now it runs everything !
    The Marine Corps Birthday is Nov 10th, so I've been busy making & painting plaques for our Marines!
    Hope O'l Bubba is still on the Zone!
    Widgit
    Attached Thumbnails Attached Thumbnails IMG_0150.jpg   IMG_0156.jpg   IMG_0159.jpg
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
