Re-Lube re can'ts,
Rocquette,my mate has a Becker VTLF500,same series as yours.Rotary vane oil less.Sounds good,no lube?There is a weird grease point which is a hole requiring a grease cartridge with a long needle.This tiny cartridge cost 85bucks Canadian.The pump was sounding bad as my mate was turning it on and off between sheets and only using it 5 hrs/week.The pump will last a long time if run all day,same as the spindle bearings.Shutting down for breaks is hard on bearings.If you cannot find the grease fitting,Jim may send over the Cam master girls to show you.:cheers:
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
