NSH GER Used Oil Regeneration System
Application
NSH GER Gas engine oil regeneration System is particularly suitable to regenerate internal-combustion engine oil including diesel engine oil, gasoline engine oil and internal-combustion engine oils. GER series can effectively remove colloid, oxid, acid, pitch, particles, impurities, water, gas in the oil. Specially, GER can restore the color of used internal-combustion engine oil and remove the scent rapidly.
Brief Introduction
Sino-NSH Oil Purifier Manufacture Co., Ltd is a high-tech Company which is engaged in researching, developing and manufacturing lubrication purification equipment.
NSH oil purification equipment series are extensively used in the fields of electric power, petroleum, natural gas, mechanical manufacture, steel, metallurgy, railway, aviation etc. which consume lubrication oil.
Product Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
Turbine Oil series
TF Turbine Oil Purifier
TF-A Turbine Oil Automation Purifier
TF-R Turbine Oil Regeneration Purifier
Lubrication Oil series
LV Lubrication Oil Purifier
LV-A Lubrication Oil Automation Purifier
LV-R Lubrication Oil Regeneration Purifier
Gas Engine Oil Regeneration System
GER Series
Contact: Anemone Tang
SINO-NSH oil purifier manufacture Co.,Ltd
EMAIL: [email protected]
TEL: 0086-23-67725736
FAX: 0086-23-67725653
URL:http://www.supplierlist.com/b2b/sinonsh11/profile.htm
ADD: NanQiaoSi,JiangBeiDistrict,Chongqing P.R.C
