603,358 active members*
3,694 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Sino-nsh Gas Engine Oil regeneration machine
Results 1 to 1 of 1
    Aug 2006
    19
    Application
    LV series oil recycling system are suitable especially for recycling and restoring hydraulic oil, machine oil, coolant oil and various other lubrication oil. The most breakdown of machinery which has lubrication oil system results from contaminated lubrication in which has water, gas, impurities etc.LV series can rapidly remove water, gas, particulate matters and impurities from lubrication oil and improve properties of lubricating oil so as to greatly extend lifetime of machinery which has lubrication system.
    Features
    Perfect capacity of removing impurities. The special filters made by NSH are made of special materials which can eliminate various impurities, water and gas effectively and rapidly.
    Automatic reverse wash system will extend the lifetime of filters and improve the performance of the filters.
    High performance security system including pressure protection device and automatic temperature controller makes purifier operate safely.
    Online work
    Easy handling and maintenance.
    Lower maintenance and replacement expenses
    Small size, light weight, low noise
    Available in mobile or stationary options.
    Various sizes and configurations (shield) available.
    Product Catalogue
    Insulation Oil Series
    VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
    VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
    VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
    VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
    GER Gas Engine Oil Regeneration System
    Turbine Oil series
    TF Turbine Oil Purifier
    TF-A Turbine Oil Automation Purifier
    TF-R Turbine Oil Regeneration Purifier
    Lubrication Oil series
    LV Lubrication Oil Purifier
    LV-A Lubrication Oil Automation Purifier
    LV-R Lubrication Oil Regeneration Purifier
    Flame-resistant Oil series
    FV Flame-resistant Oil Purifier
    FV-A Flame-resistant Oil Automation Purifier
    Explosion-proof series
    EV Explosion-proof Vacuum Purifier
    EV-A Explosion-proof Vacuum Purifier
    EP Explosion-proof Precision Filtering Purifier
    EP-A Explosion-proof Precision Filtering Purifier
    [email protected]
    http://oilpurifier.ec51.com
