587,600 active members*
4,396 visitors online*
    May 2017
    23
    NC Studio Limit switches problem
    Hi guys.
    Please can somebody learn me how to definitely get rid of ncstudio limit switches problem.
    I have never succeded matching the cross on the simulation screen with the origin of the work area.
    And everytime I have an electricity cut while working, I have to hazardously try to find the work origin.
    What to do ???
    Jan 2018
    1516
    Re: NC Studio Limit switches problem
    Quote Originally Posted by bivegele View Post
    Hi guys.
    What to do ???
    Work origin?
    Limits are not for the work origin, they are for the MACHINE origin.
    This is 2 different things.
    You set the limits so an axis can't travel past it's ends in machine origin co-ordinates.
    Your work origin co-ordinates are positioned by the user themselves.
    Then. If you set a starting co-ordinate for a part that puts the part out of limit bounds it will tell you. You then need to reposition your part until it fits on the table space. The cross pretty much means nothing it just shows you where YOU have set the WORK co-ordinates on what the MACHINE thinks is the table size area relative to it's ends/limits. (that's IF you have set it up properly in the first place).
    If the machine does not know where it is, you will always have problems.
    You really need to do some hard reading / video watching of the cnc program you're using ie mach3 or other type, and know all of this properly.
  1. Limit switches problem
    By kjetilhansen in forum Mach Mill
    Last Post: 01-28-2015, 05:42 PM
  2. Help Please A Newbie Problem (those darn home ands limit switches)
    By PhireDog in forum DIY CNC Router Table Machines
    Last Post: 06-16-2013, 10:21 PM
  3. Problem -- limit switches shorting
    By rusel in forum CNC Machine Related Electronics
    Last Post: 08-23-2010, 03:40 AM
  4. Problem with indexer limit switches
    By johnhb in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2009, 07:22 PM
  5. Problem with wiring limit switches to Delta Tau Pmac
    By jatchan in forum Servo Motors / Drives
    Last Post: 02-09-2009, 02:41 PM
