587,768 active members*
3,881 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Problem with wiring limit switches to Delta Tau Pmac
    Feb 2009
    6
    Hello all
    I am a beginner trying to hook up a 3-axis spindle machine with my delta tau Pmac Pack. Here is the suitation.
    The spindle has x,y,z axis and each axis has limited switches located on both ends. I connected the spindle's limit switches +x and -x to the Pmac pack's Flag input 1 PosLim and NegLim. I expected that the spindle will stop moving if I press the either one of the overlimit switches. However, nothing happened when I pressed. What should I do?
    P.S. When the limited switches are not pressed, both PosLim and NegLim are 3.9V. If limited switch +x is pressed, voltage of PosLim changes from 3.9V to 0.15V. Only PosLim and NegLim are connected, other pins of Flag input are not connected.
    Oct 2005
    105
    It sounds like you have Ix25 (replace x with motor number) set wrong.
    PMAC limits needs to be pulled low to enable. They should be wired with normaly closed switches.
    So when the machine is not on limit it should be close to 0 volts and go up to around 5 when the switch is pressed.
  1. Delta Tau PMAC-Lite
    By TravisR100 in forum Servo Motors / Drives
    Last Post: 11-22-2012, 01:27 AM
  2. Wiring home and limit switches
    By Hack in forum CNC Machine Related Electronics
    Last Post: 01-24-2009, 10:47 PM
  3. Delta Tau PMAC Defiance VTX-1
    By VTX-1 in forum Want To Buy...Need help!
    Last Post: 09-19-2008, 01:47 AM
  4. Delta Tau PMAC Pack
    By Poinciana in forum Servo Motors / Drives
    Last Post: 06-12-2007, 10:35 PM
  5. Wiring IH limit switches
    By Shepard in forum Charter Oak Automation Support Forum
    Last Post: 03-21-2007, 02:28 AM
