588,076 active members*
5,022 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > newbie profile milling with a ball end mill
Results 1 to 6 of 6
    Jan 2013
    5
    I have been trying to write a conversational program with no luck for our Milltronics Centurian 7 to put a concave radius on the end of a round pin using a .062 ball nose cutter. The dia of the pin is .686 and the radius is .375. The problem I've been having is the cutter wants to make a pass on the outside edge of pin when it begins, then start inside. This will wipeout the end of my pin. Any help would be greatly appreciated. I have attached a dwg if it helps.
    Attached Files Attached Files
    Apr 2003
    637
    Why not just plunge a .75 ball or at least a larger ball than .062?
    Apr 2003
    637
    Sorry bobref, I didn’t get time to finish what I wanted to say in the above post. I’m not familiar with the Centurion 7 control but if you want I can create a tool path in Surfcam for you if you PM me. We just took delivery of a VM20 with the 8200 control that is supposed to do 3D on the control, something our older Centurion 6 couldn’t. Not sure if I’ll take time to learn it though. We use Surfcam for 100% of the programming as it is.
    Oct 2008
    427
    Take a look at this example:
    I used cad to get a couple of numbers, I could have done a couple of trig calculations to get them but the cad is faster.
    Conversational Program C:\\parts\P0001
    Event 0 of 5
    Program Setup
    Program name [CONCAVE RADIUS ]
    Dimensions [Absolute]
    Units [English]
    Work Coordinate [---]
    Setup Notes:
    Event 1 of 5
    Tool Change
    Tool [Change]
    Tl Chng Position X[ ]
    Y[ ]
    Tool Number T[1 ]
    Tool Description [1/16 BALL END MILL ]
    Spindle Speed S[5000 ]
    Spindle Direction[CW]
    Coolant [Flood]
    Event 2 of 5
    Tool Pierce - Start Mill Cycle
    Z Pierce Feedrate [10 ]
    Return Point [Clearance]
    Clearance [.25 ]
    Final Z Depth [-.2234 ]
    1st Z Depth [0 ]
    Z Increment [.025 ]
    X Pierce Point X[0 ]
    Y Pierce Point Y[.343 ]
    Compensation [Auto Left]
    Options [Round Walls(ball nose)]
    Wall Radius[.375 ]Start Angle[23.816 ]
    Event 3 of 5
    Mill Geometry - Arc
    Plane [XY]
    Feedrate F[15 ]
    Direction [CCW]
    Center [Abs Center]
    Arc Radius R[.343 ]
    Arc CenterXC[0 ]
    YC[0 ]
    End Point [Polar]
    End Angle AB[90 ]
    Z[ ]
    End Option [---]
    Event 4 of 5
    Tool Retract
    End Mill Cycle
    Point on part after tool retract
    [Auto]
    Call Island #[ ]Call Island #[ ]
    Event 5 of 5
    End of Program
    Spindle off [Yes]
    Coolant off [Yes]
    Z to Home Position [Yes]
    X Position (Home relative)[ ]
    Y Position (Home relative)[ ]
    Jan 2013
    5
    Thanks for the responses. ZZZZ I will give that program a try at work tonight. @ Moldcore your response about the .750 ball end mill is how we did it the last time. Worked OK but we have other pins that are the same style but dimensionally are different so were not able to do it that way.
    Jan 2013
    5
    Thanks ZZZZ. Ran the program and it worked fine. I have only been using the machine for a couple months so still stumbling through things. One thing I do question is the start angle? When I did my trig I came up with 23.845. So either my math is wrong or I do not know how or where to calculate it from. Would you be so helpful as to show me how to figure that out. It would be greatly appreciated. I also thought the machine had a trig help function as well?
    Bob Ref
  1. 2D Profile Milling
    By jemarkey in forum BobCad-Cam
    Last Post: 01-10-2013, 08:18 PM
  2. Compensation in Mill-Turn Profile contour milling
    By maparkopo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-26-2012, 03:11 PM
  3. milling out profile using MILL-CAD function
    By poster in forum Milltronics
    Last Post: 09-16-2011, 11:19 PM
  4. Newbie help w/ Profile toolpath
    By EndIsForever in forum Rhinocam
    Last Post: 10-03-2009, 05:43 PM
  5. Drilling / Milling Stone - Large Diameter Ball End Mill
    By oscarbam in forum Material Machining Solutions
    Last Post: 08-27-2008, 11:29 PM
