587,633 active members*
3,348 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > RHINOCAM ALWAYS POSTS TO MACH IN INCHES.
Results 1 to 6 of 6
    Apr 2006
    59
    I set up my RhinoCAD profiling model in mm and posted it to Mach via RhinoCAM.
    The resultant G codes are always in inches. ie G20 not G21
    I am nearly done coding in VBA to effect the conversion of the lines of G code to mm but want to know how I can set RhinoCAM to post process in the native unit - mm- of my models.
    Any help please?
    Jan 2007
    38
    From memory it is done in the Post Processor. When you edit the processor these is a box to tick. If you cannot find it I'll go look
    Noel
    Apr 2006
    59
    Thanks bud. But can you be a little more specific please?
    I visited K2CNC's site and there are some links there that are supposed to help. k2cnc.com/Mach2_Mach3_setup.asp
    It did not work for me. I will also look at this later in the day.
    Jan 2007
    38
    In RHINOCAM Browser click setup TAB, click the hammer spanner icon select Post Processor Generator, Click on MACH2, Edit. Under general tab select "mm"
    Apr 2006
    59
    I really thank you. It was really quite easy and very helpful.
    Jul 2009
    16
    Thanks, my problem is solved too.
    http://tw.myblog.yahoo.com/cncfreakcncfreak
  1. metric to inches
    By cinci5 in forum Mastercam
    Last Post: 03-21-2009, 01:19 PM
  2. To Be or not To Be in Inches
    By weirdharold in forum UG NX
    Last Post: 01-22-2009, 04:30 PM
  3. Inches and mm
    By jorgehrr in forum Solidworks
    Last Post: 02-04-2008, 10:43 PM
  4. BobCAD posts vs. Mastercam posts
    By justCNCit in forum BobCad-Cam
    Last Post: 08-16-2006, 08:17 PM
  5. inches per minute
    By planescott in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2006, 01:29 AM
