587,999 active members*
2,700 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 Spindle Motor Frame Size?
    Jan 2010
    Sorry if this has been covered before, i really did search for a long time i promise!
    Does anyone know the frame size of the stock spindle motor? Or has anyone found a drop in replacement that doesn't suck so bad? I'm hoping to find a 3phase ac motor that will fit the stock rpm/shaft/flange, so i can dump the controller as well.
    Thanks in advance!
    Jan 2010
    151
    I don't know the frame size but there are lots of motor and controller options here. Projects
    Jan 2010
    I finally got to the shop to take some measurements. It appears to be a metric d63 frame with a b14 face except the shaft is 10mm instead of the 11mm standard.
  1. Possible G0704 high speed spindle motor,
    By Turbo442 in forum Benchtop Machines
    Last Post: 06-25-2012, 09:33 PM
  2. What is benefit of NT 30 spindle, what is frame size of motor?
    By JohnToner in forum Charter Oak Automation Support Forum
    Last Post: 10-09-2011, 07:42 AM
  3. What Size Aluminum To Use In Frame?
    By thomasholley in forum DIY CNC Router Table Machines
    Last Post: 08-18-2011, 08:25 PM
  4. Spindle motor size Vs feeds & speeds
    By TMaster in forum MetalWork Discussion
    Last Post: 09-11-2009, 10:50 PM
  5. Spindle for metal and wood. Motor size question
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 05-20-2005, 05:15 PM
