If you take the red cap off the rear of the motor, you will see the encoder cable and also a pair of individual wires, usually white or black that come out of the motor winding, this is the thermal sensor.
These go to the canon connector and should measure closed circuit.
The termination for these are usually labeled OH1 OH2 etc.
Depending on the drive, these usually end up in the Honda connector on the bottom of the drive.
100A 100B are usually a 100vac input.
What is the model of drive?
Al.
Albert E.
