587,210 active members*
3,029 visitors online*
Thread: BobArt help
Results 1 to 6 of 6
    Mar 2006
    24
    BobArt help
    What's the best method for machining this path emboss in Bobart? It's aprox 5in X 2.5in... V cutter? I'm having trouble with the setup inside of Bobare specifically. Anyone have experience using it? How would you set this up to mahcine on a .25 X 6 X 3 in part for example? I'm just about ready to eat the pages of the bobart manual to get some more substance from them :-)
    Zipped file to get it to fit on the post -
    Attached Files Attached Files
    Jan 2006
    4396
    Quote Originally Posted by Dfennell View Post
    Have you posted here http://cadcamtrainer.com/forums/index.php and here http://216.117.147.20/bobcadsupport/forums/index.php too?
    I bought BobArt ProX to play with but haven't done that much with it. Try posting in those forums and someone will be able to help you. Actually most of those members are here too but it is best to post you question everywhere.
    Is this what you want? Follow this link http://cadcamtrainer.com/forums/show...3&postcount=58
    The Zip I saved wouldn't upload here so I put it on Sorin Nenu's Forum CAD/CAM Trainer. I think your a member already but if you aren't, just register . Your file is waiting for you. I hope you have a fast internet connection because the zip is 3.16MB.
    Don't understand why it wouldn't load here.
    Attached Thumbnails Attached Thumbnails Iron Maiden Eddy.jpg   failed upload.JPG
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Mar 2006
    24
    Thanx Tpby, I'll go log on over there and check it out ( and make a post). The Bobart portion of the the program has been a bit tricky.
    Jan 2006
    4396
    Yes it is. I really never use it but sure someone out there does that can really help you a lot.
    Toby D.
    Schwarzwald
    Aug 2005
    301
    Bobart
    I am having great difficulty with Bobart. I am running v24 and trying to go from a photograph to a toolpath. Nothing that I do seems to work. I am familiar
    with BC but Bobart just does not work for me.
    I have the video series on Bobart but they do not show anything being done with a photograph. Is there something available, that I have not found, that will show me how to go from a PHOTOGRAPH ( I am not shouting, just emphasizing )to a toolpath?
    Ernie
    Dec 2008
    4548
    Here is an example at the simplist level.
    [nomedia="http://www.youtube.com/watch?v=Q1L3TADKxJA"]YouTube - simple bobart[/nomedia]
    This is V23 but i dont think anything has changed..
    The yellow surface created you can think of like a regular surface...(Just cant do geometry operations on it, like cutting and such)
    Toolpath it with something like a slice planar...
  1. BobArt pro x
    By bbergami in forum BobCad-Cam
    Last Post: 06-04-2006, 04:53 AM
  2. Can Bobart be run without
    By zonker in forum BobCad-Cam
    Last Post: 01-04-2006, 04:03 AM
  3. Bobart Pro X
    By Randall in forum BobCad-Cam
    Last Post: 08-16-2005, 05:33 PM
  4. Bobart pro X?
    By fastolds in forum BobCad-Cam
    Last Post: 06-27-2005, 03:51 PM
  5. BobART 2D
    By CNCdude in forum BobCad-Cam
    Last Post: 07-27-2004, 03:06 PM
